WD 45 Gear Oil Leak
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Gear Oil Leak
    Posted: 15 Jul 2011 at 12:22pm
Have owned this tractor for 4 years and have a leak which seems to be getting worse.  There is transmission/rear end gear oil leaking in the area of the snap coupler bell and dripping off the area where the bell if pinned to the tractor.  Haven't been able to determine exactly where it's coming from.  Appreciate any input for a remedy and obviously trying to avoid the splitting process.  Other than the mess--may just keep adding the gear oil for a while.  Thanks for any suggestions.
Dennis J
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 4:55pm
take a close look at the PTO drop gear box. common area to leak easy to fix. just drai and remove from tractor to work on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 6:00pm
Thanks Dave, I don't have the tractor with me but will take a closer look at it next week.  I'm thinking it may not be the PTO, I've had it off about 3 years ago and regasketed it and the drip is not off the PTO unless it's finding a way to flow further back to the whole drawbar mounting brackets.  Not sure if the bracket bolts for the drawbar or the bolts coupling the torque housing to the transmission differential housing actually penetrate into the castings allowing gear oil to seep around the bolts or if the gasket is just bad which would require a split.  Thought about putting in some dye (if available) to try and get a bettter origin of the leak.  Again, thanks for the ideas.
Dennis J
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 6:33pm
The six split bolts are probably loose that connects the rearend to the torque housing.....takes a 3/4 wrench.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 7:22pm
Thanks Dr. Allis, I'll certainly check that out and give it a try before doing anything else.  Thanks again,
Dennis J.
