new holland 268 hayliner question
craigreavley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craigreavley Quote  Post ReplyReply Direct Link To This Post Topic: new holland 268 hayliner question
    Posted: 01 Jul 2011 at 8:28pm
baled tonight, and the baler knots are coming apart. The one side ties and both ends of the string are not hanging past the knot. One of the strings is only half out of the knot and the other half is wrapped in the knot what would be causing this
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 8:30pm
  CHECK THE BILL HOOKS FOR WEAR OR BENT
Post Options Post Options   Thanks (0) Thanks(0)   Quote craigreavley Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 8:40pm
i am not sure what a worn billhook would look like. There is some play up and down on the bill hook shaft the good knotter is tight the bad knot side has an eighth inch play up and down on the billhook shaft could that play be the issue
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 9:22pm
The side with the looped knot: I don't have a book here but that is a common problem,  I can tell you it is almost never a billhook (worn will have a grove, in the hook or the tuque )  make sure it is smooth if not steel wool it until  all rust is gone and roughness is gone.  I'm thinking it is tension at the twine box, or twine holder, I know the 273 NH twine holder at the knotter can break very easy if over tightened. Just a piece of spring steel, sometimes they wear out. You should not be able to pull the twine out of the knotter easily, should take about 60-80 lbs to pull it out, only make it tight enough to hold the twine to make a knot.   There is also a tensioner on the billhook that need to be checked.
The uneven knot ends maybe a the knife needs sharpened.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2011 at 4:26am
What Teddy said,make sure knives are sharp.
mtanut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtanut Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2011 at 5:30am
Other thing to check is the knife arm. Take the bolt out of the bottom of the knotter, then swing it up in the air, pull the cotter key and remove the knife arm. There is a brass ball on to of the arm and over the years it will develop flat spots on it.When the knotter cycles it won't work smooth and hang up in the casting, hence the not cutting right and  hanging up on one side. Good luck balers are a love hate relationship.
I have a 185 Allis, 6060 Allis, Model K gleaner, SMTA ferg 35, ferg 20 (paps first tractor, Allis B (wife's)John Deere 240 skid loader and a bunch of the usual farm stuff.
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2011 at 7:06am
I would check for a bent twine finger. It sounds like the #2 twine is not being delivered to the knotter properly. Also make sure the twine discs are timed properly, if there not uneven cutting of the string will result. As well bill hook tongue pressure may be too light resulting in the ends of the twine pulling out of the billhook before the knifearm can wipe the knot off. Good luck
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2011 at 11:23am
CHECK THE GEAR ON THE BIRDBILL THE FLAT SPOT SHOULD BE COMPLETELY FLAT.IT LETS THE BIRDBILL MOVE TOO MUCH IF WORN
This page was generated in 0.172 seconds.
