HELP 7010 powershift Dr Allis Mack |
Clay Bragg
Topic: HELP 7010 powershift Dr Allis MackPosted: 28 Jun 2011 at 9:13pm |
I was mowing hay with my 7010 powershift today,(disked 200 acres with 20ft 480 international disk last month with no trouble)ground speed started slowing down.looks like hyd oil coming from behind the flywheel.can something screw up to cause excessive trans preasure?1800 rpm light has always worked properly and is not on abnormally.Anything to check before I split it?anything else to service inside while its down. thanks Clay
MACK
Posted: 28 Jun 2011 at 10:01pm |
If it is hyd. oil, the nut on ftont of PS may have come off. If the nut came loose it is a complete rebuild.
If you are lucky it is engine oil from rear main seal. MACK
Clay Bragg
Posted: 28 Jun 2011 at 10:31pm |
definatley hy tran wher can i purchase some good splitting stands? |
bill2260
Posted: 29 Jun 2011 at 6:44am |
What causes the nut to come off power shift? Have seen post on this before. Thanks, Bill
DrAllis
Posted: 29 Jun 2011 at 6:50am |
The locking tab ring allows the nut to start to work loose and then eventually shears off the tab and then bad things happen. It is not terribly common but, as these tractors get older we may see more. Whenever I have a PowerShift tractor split for any reason, I put a stake/center punch mark on the inside diameter of the nut, inline with a keyway on the clutch housing nose so the nut can't ever back off. If I ever need to remove the nut for trans repairs years down the road, I use a sharp chisel and split the nut at the center punch mark.
MACK
Posted: 29 Jun 2011 at 7:25am |
I have seen the housing break off behind the nut, have saw the threads stripped with the lock still in tack. No good reason, but it happens from time to time.
As far as splitting stands, a set to support the motor is all you need. Remove the PS with the motor then remove PS from motor. MACK
Clay Bragg
Posted: 29 Jun 2011 at 4:56pm |
can you check clutch packs for wear or would you just replace them all?torque limiter?Bearings?thanks |
Carl(NWWI)
Posted: 29 Jun 2011 at 5:11pm |
here's a good place for stands, spendy, but safe..
MACK
Posted: 01 Jul 2011 at 12:38pm |
I would replace clutch plates in C1 and A2. Any others thar are warped or has foreign materal through them. As far as wear, check the splines on plates for wear. The plates very seldem wear unless they are warped. MACK
