45 gas valve cover torque spec
IndianaBuckeye View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IndianaBuckeye Quote  Post ReplyReply Direct Link To This Post Topic: 45 gas valve cover torque spec
    Posted: 24 Jun 2011 at 1:00pm
Does anyone know the valve cover torque spec for a WD 45 gas?  Thanks in advance!
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 1:36pm
Snug and then a schosh more. Don't overtighten. Factory service manual simply sez to tighten evenly and don't crush the cover.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 2:16pm
Right, No specs
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 4:31pm
Is there a cover that is better than others?
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 8:36pm
5/16 18 bolt coated in nickle neverseize has a k factor of .158 stress level of 15000 psi would be 20 inlbs 30000 is 39 inlbs  45000 59 inlbs. t=k.d.og.ag/n.12
t=assembly torque value
k=nut factor
d=nominal fastener diameter
og=target gasket stress (psi)
n =number of bolts
Ag= gasket stress area (in^)
12= conversion to Ft-lbs
Hope this helps. Formula comes from guidlines and methodology for assembling and tensioning threaded connections.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 7:47am
k=nut factor
n =number of bolts
Indiana Buckeye,  The quote above is the gibberish your child may spout if dropped on their noggin too many times , then  a calculater will be needed to do most anything.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 7:56am
Mitch, you never cease to amaze me..
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 8:42pm
The ones who amaze me are the ones who dont  comprehend mechanical engineering like Garry. The guy asked for a torque value I gave him one .Then told him how to figure one for the compressability of cork /fibrous gasket so that he wouldnt squeeze it into or out. It would be nice for once to have a technical forum I guess thats to much to require.
