D-19 engine swap
BPM75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Topic: D-19 engine swap
    Posted: 11 Jun 2011 at 5:56pm
I have recently got a d19 gas in pretty rough shape the motor is stuck and has many parts missing, but the tactor has fas factory 3pt that is complete, what i want to do is make this tractor a diesel,I have found a couple of 262 diesels from d17s but also found 301 from a combine, my question is will the 301 bolt up to the d19 tractor or how much modification will i have to do? Just thought maybe someone has already tried this, i would be greatful for any help or info. Thanks
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 6:11pm
I put a 301 in a D17 gas series 1. Pretty easy swap. It will bolt up. I had to modify frame rails. The clutch and housing was fairly easy, 190 clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 6:44am
Thanks for the info, if I can get it bought right I think ill try it.
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 7:24am
If you junk the 262 please let me know I need a governer from a D19 gas
Thanks
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 6:41pm
Ill let you know when i get it off
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2011 at 10:09am
Are you still looking for a diesel conversion motor?
I have a Nissan diesel motor that is in a D19 tractor. It is rated at 90 Hp, It runs excellant, has all mounting plates, fits very nicely.
Mottwelding View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mottwelding Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 8:17pm
hey did you ever sell that engine and adaptor plate?
