Diesel mixed with gas???? |
Page 12> |
AC WD45
Joined: 28 Sep 2009 Location: Mid Michigan Points: 2078 |
Topic: Diesel mixed with gas????Posted: 07 Jun 2011 at 8:47pm |
Really? I had a farmer tell me once he mixes his gas for his old (D17, WD45, John Deere A) tractors with 1 part diesel to 10 parts gas. says it counters the ethonol in the gas and they run better, especially the JD A?
German Shepherd dad
1957 Allis Chalmers WD45 #WD234847 1951 Allis Chalmers WD #WD88193 |
Tedin NE-OH
Posted: 07 Jun 2011 at 8:54pm |
Sounds like an old wives tale.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5148 |
Posted: 07 Jun 2011 at 8:58pm |
diesel burns slower than gas, thus giving the effect of higher octane. I have heard of it being done, but that was many years ago.
dustinmo
Joined: 12 Sep 2009 Location: Auxvasse, MO Points: 2187 |
Posted: 07 Jun 2011 at 9:01pm |
I add 2 cycle oil not always but when I think of it to the tanks on all my tractors that are gas anyway, I believe it helps to keep the valves from sticking, and I bought a couple cases of 2 cycle quarts at a sale one day a few years ago
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Hmmm,,,what ratio would it have to be to render a gas vehicle inoperable, not damaged, just inoperable?
I have some theft problems at my place.
Edited by JoeO(CMO) - 07 Jun 2011 at 9:01pm |
Dipstick In
Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
Posted: 07 Jun 2011 at 9:06pm |
half and half might work, at least it should stop pilferage!
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 07 Jun 2011 at 9:14pm |
I can tell you all he is doing is dilluting his oil and lowering the octane. Been there and done that. Since the BP station in the next town over has more clearly marked the diesel pumps, I haven't had to drain gas from diesel pickup fuel tanks in quite a while. Since the oil recycler doesn't want anything but oil in the waste oil tank, I ran the mixture in my 98 Chevy. The highest "blend" was 25% diesel, 75% gas. The 75-25 made the engine ping and dilluted the oil. It doesn't help.
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Posted: 07 Jun 2011 at 9:15pm |
LOL There's a guy named Butch on here that runs JP-4 in his kerosene A. At least that's what it smells like to this old huey pilot.
Brian Jasper co. Ia
Posted: 07 Jun 2011 at 9:20pm |
Dennis(IA)
Posted: 07 Jun 2011 at 9:22pm |
When I was working we had customers that would accidentally put diesel into the gas tank of a lawn mower. It kind of gets you thinking until you remember to take the gas cap off and smell the gas. Anyway, I am sure that a 50/50 mix would not run. I did take some of the diesel gas mix home one day thinking I would put a little at a time in my tractors. Then mowing the lawn I ran out of gas, so all I had was the diesel gas mix and I put it in and finished mowing. Went to use that mower a week later and it would not start, %#%&* mower never fails to start. Then I pulled the spark plug and smelled diesel. Had to drain the carb and put in fresh gas. Kind of like the old fuel burning tractors, they had to start on gas, then after warmed up switch to tractor fuel. |
DrAllis
Posted: 08 Jun 2011 at 6:17am |
10 or 20% diesel fuel added to gas will make your car detonate under load and smell like diesel out the exhaust.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12043 |
Posted: 08 Jun 2011 at 6:35am |
I've heard of these different concoctions, but never heard of any of them being successful. I remember my Dad dumping Kero in the old engines and running them a short while to clean the crankcase out. Then changing the oil, and its ready to go to work again. Used to wonder how the bearings handled that menuvuer....
Rawleigh
Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
Posted: 08 Jun 2011 at 9:55am |
Don't do it!!!
Dakota Dave
Posted: 08 Jun 2011 at 10:06am |
I have run a couple tanks of 20% diesel in my C. It ran hotter and cleaned the carbon. ran much better after that than before. Your car is not as forgiving. the higher compression will cause detonation and engine damage.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42086 |
Posted: 08 Jun 2011 at 10:13am |
Way back when diesel or #2 heating oil was 1/2 price of gas had a guy that came into station and bought 15 gal of gas and 5 gal of #2 in his car, old Buick straight eight. Filled up once a week with this.
The rinseing a engine out with diesel kind of worked but adding a couple quarts of ATF works also in some older engines as long as they are not run hard or long after adding .
On the old B JD i had i used diesel a few times in the starting tank to run it while mowing but no great savings of money in the long run.
Now the HD5 ran OK using the gas from Suburban after wife filled it with diesel once. mixed it down with more diesel so about a 10% gas. 90% diesel mix. Edited by Coke-in-MN - 08 Jun 2011 at 10:15am |
Roddo
Joined: 16 Jul 2010 Location: Brant, Ontario Points: 466 |
Posted: 08 Jun 2011 at 10:52am |
Sounds like all Ford dealers are alot alike Brian. Ive used the mix from gas in diesel miss-fills in my dads Deere combine and Tractor many times. They burn it up no problems!
Brian Jasper co. Ia
Posted: 08 Jun 2011 at 10:58am |
Yeah, it was mostly folks just passing through. The CA and Oliver 60 didn't ping any that I could tell, but about all they do is give rides. They did start a little harder and smoke some though. The lawn mower hated it. |
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 08 Jun 2011 at 11:08am |
Put 1 gal diesel in full tank of gas in 64 chevelle , about 20/1 Seemed had little more power coud see slight hase when tromped on . Tolled a guy at work. he put 5gal in a bettle . Guess what quit on him going home . More is not always better.
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 08 Jun 2011 at 1:05pm |
A friend of mine mistakenly topped up the tank on his Dodge truck with gas instead of diesel. There was enough diesel that he drove home ok but when it wouldn't start the next day he realised his mistake. I helped him drain the tank and prime his fuel system with fresh diesel to get it started again. I took the mixed fuel home and tried some mixed with about 1/2 tank of gas in my 86 GMC Jimmy and it didn't like it. I suspect the main problem was due to the the computer and fuel injection system getting incorrect information from the O2 sensor. I did use the rest of the mixed fuel up by thinning it more with gas and using it in the lawn tractor and lawn mower.
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 08 Jun 2011 at 2:22pm |
When I was farming with the Oliver 1850's and an Oliver 1650 the gas man said to put one quart of diesel to every tank of gas. The 1850 tanks held 43 gallon. He said his boss had told him to advise all of his farm customers to add diesel to the gas when they no longer had anything but unleaded gas. I did it when I would think about it. Not sure if it helped lube the valves enough to off set the lack of lead or even if it needed the extra lube. I never saw any data that said it helped so it could have been someones opinion. I have not added diesel to gas for years and have not had valve problems.
Coke-in-MN
Posted: 08 Jun 2011 at 2:32pm |
In hot weather adding diesel to older engines was a way to prevent vapor lock on some of them. Remember one trip I made in old 6 cyl GMC converted school bus where it vapor locked out in middle of SD in hot weather .. Next fuel stop added diesel and ran fine.
Dipstick In
Posted: 08 Jun 2011 at 2:52pm |
After I retired from farming I delivered new Wabash National trailers from Lafayette, In. to whereever. One night I dropped a reefer at Mondovi, Wi. to "blue bird" trucking. It was late and I was tired so I went out to the Interstate and pulled into Haekels Restaurant and went to bed. The next morning I ate breakfast and thought maybe I should check the oil since it was settled. The stick read at least 2 to 3 GALLONS over full. I smelled it and sure enough it was full of diesel. I called my mechanic at Fort Wayne, Indiana and told him the story. I also told him that I was "bobtailing". He said can you drive it here and we will pull the pump and drain the oil and get it fixed. I said, sure, but shouldn't I at least drain and put new oil in. He told me no, cause diesel is an oil, light weight, but still an oil. Now if it were gas I would have you put it on a hook cause it would wash out the bearings. I did it, but was a nervous wreck for 2-3 oil changes and had samples pulled, but it did not damage anything.. Still, I would NOT recomend anyone else experimenting that way!!!! |
ky wonder
Joined: 13 Apr 2011 Location: horse cave, ky Points: 647 |
Posted: 11 Jun 2011 at 3:22pm |
years ago, back in my youth, in the late sixties, early seventies we did this in reverse on the old diesels, if we where going to pull the tractor we would mix a little ( and i do mean a small amount) high octane gas in with the diesel, and watch the flames come out the top of the stack, it made a differance in power but i would not dream of doing that these days
i like old tractors of all colors
ToddSin NY
Joined: 08 Nov 2009 Location: Newark,NY Points: 1034 |
Posted: 11 Jun 2011 at 4:43pm |
We mix gas and diesel and pour it down woodchuck holes then light it! Cover the hole with dirt and never see wood chucks out of that hole again. Does this count??
AC WD45
Posted: 11 Jun 2011 at 5:02pm |
Todd: 2-4-D and Diesel fuel makes a good ragweed killer. and they don't grow back. also good for ground bees, woodchucks, skunks, annoying neighbors dogs, ahemm....chipmunks, annoying neighbors gas tanks *cough cough*
German Shepherd dad
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3595 |
Posted: 11 Jun 2011 at 7:33pm |
I am doing just the opposite. I am nixing gas with used motor oil and runing it in my 99 power stroke. Running a tank of 17% gas and adding 5 gal D2.
Mmmmmmmm, black diesel!
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6108 |
Posted: 11 Jun 2011 at 10:48pm |
I've got a '42 Kohler genset that has a 140ci Waukesha flathead, ignited by magneto... I can start it, get it warm, and switch it over to diesel... and it'll run nicely with a slight mixture adjustment. Best not to shut the engine down while running on it... I switch back to gasoline, so it'll start nicely when cranked up next time.
Is it better? is it good for it? well... you certainly won't get higher performance without some major retuning... but if you have large quantities of it available at a very low cost, finding a way of using it only reasonable. That's what they did through the early-mid '30's anyway. They used a small tank of a more volatile distillation byproduct called 'gasoline', and once running and warm, switched over to 'distillate'... or 'tractor fuel'. Of course, it DID find it's way past the rings and filled the crankcase a bit, so there was two drain petcocks on the side of the oilpain... open the upper one, drain off the stuff on the top... after all, the heavy stuff fell to the bottom... light stuff stayed on top... And whatever drained off, well, it went back in the tank... or if it was wintertime... into the radiator... 'cause it wouldn't freeze... But it works better on lower compression engines that are well warmed, with plenty of ignition power. Because the burn rate and heat energy of a volume of a fuel type is different from another, when a combustion method is optimized for one type of fuel, it will not be most efficient for another. Multifuel operation requires that either an engine be able to be optimized on-the-fly... or that it's design be set up very conservatively, so that it will function successfully under a wide range of conditions. Modern engines are so optimized for efficiency on a given type of fuel, that expecting them to run satsifactorily on another, is asking alot. Furthermore, modern road engines are equipped with emmission control systems that have no leniency (both in operation, and under EPA regulation) to tolerate fuel mixes without major drawbacks. Modern engines also don't tolerate oil dilution and contamination products very well... they're squeezing every bit of energy out of fuel, and doing it in a very lightweight, compact package... and really only work 'hard' under intermittant duty conditions... totally opposite from a 50+ year old tractor... so what is gained in performance, was lost in flexibility... Edited by DaveKamp - 11 Jun 2011 at 11:06pm |
DaveKamp
Posted: 11 Jun 2011 at 11:06pm |
On another note... when our service fleet ran 7.3l Diesels, extreme cold
temperatures were combatted with one gallon of premium gas for each
fillup of diesel... never had any problems with gelling, and had no
adverse effect on performance. We had nothing but loss of performance,
lack of durability, poor fuel economy, and extended duration downtime
(oftentimes 'stranded' for a week or more) as a result of the 'newer' PS
engines, so our most recent series run V10 gas power. A little less
horsepower on tap during all seasons... except winter. Much more power
on tap during -25F days... and best of all, I've put 70,000 miles on my
latest chassis, and NEVER had it in for any kind of repair... NO
BREAKDOWNS... just regular maintenance. Haven't seen that level of
reliability since the 7.3L...
Brian Jasper co. Ia
Posted: 12 Jun 2011 at 12:05am |
The 6.7 seems to be a winner mechanically so far. Drawbacks are the DPF and Urea adding to the cost per mile though. If you like the V10, hang on to it. They don't make them any more.
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 12 Jun 2011 at 1:26am |
A one thing to remember is distalate tractors had lower compression ratios so knocking the octane rating down would help a distalate tractor.
Page 12> |
