8030 vs IH 1086 or 1486
gh-in-oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gh-in-oh Quote  Post ReplyReply Direct Link To This Post Topic: 8030 vs IH 1086 or 1486
    Posted: 02 Jun 2011 at 7:41am
I have been wanting another tractor for a long time, now i am actually starting to look for one.  Dad always had allis chalmers (d17 being the largest), so i have a soft spot for the orange.   I currently have a 1066 and it has been a very good tractor to me.  Anyhow, i think i have it narrowed down to an allis 8030 or an IH 1086 or a 1486.   Just looking for opinions on the 8030.  Biggest concern is getting parts.   Tractor will be used for tillage work as well as making hay in the summer.   Thanks for any suggestions you can provide
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 8:52am
Never been around any of the 8000 series.  Dad has a 7060 and at one time ran it side by side with a 1066. (still my favorite tractor of all time).  The 8000 series cab is a lot better than the 86 IH.  The IH also has the gears on the left side.  Ok, but takes some getting used to.  A 1486 will probably out horse an 8030, but the 1086 would be about the same.  I'm a bit of a binder guy, but the 8030 is probably the better overall machine.
AaronSEIA
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 10:24am
FWD will be an option on the 8030, but rare on the 86 series. This would be a boon for tillage work as it will outwork a heavier tractor.
Charlie
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 10:56am
Sit in both cabs.  If you are still considering the IH afterwards you need your head examined.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 10:58am
If you do much tillage work and find an 8030 FWA, you'll be a very happy camper the next time you drop an implement in the ground.
Mark
GTH-L Simplicity
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 11:54am
I think the ac drivetrain will be better too no dry clutches or TA's the 8000 series is a step ahead, it would compete more with the 88 series IH
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 11:55am
I would go for the 8030.
amo1977 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amo1977 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 9:41pm
How reliable were the FWA's?  I have seen a few 7XXX with it.  Anything good or bad about the crank, rods, mains, supports, etc?
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 10:41pm
OWNED an  8030 fwd for 16 years puttingand 4000 hours on it. Hardly any down time. Changed a universal joint in front end . Added a grease fitting to the new joint.
Installed one set of tires and installed air seat to rplace the original suspension
which broke.  8030 is   a great tractor.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 10:46pm
8030, looks better, is cheap hp, has a better cab. i too like the ih's, the 1486 will be to much for haying, unless using the big square balers. the 1086 is a good all around tractor! as is the 8030! if you go with the 10 or 14, make sure it has the newer updates on the tranny levers. or it'll stick in park and a forward gear, letting out the clutch....shells the rear end and tranny!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gh-in-oh Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 7:47am
Thanks for all the replies folks.   Posted the same question on other forums and got pretty much the same answers as what everybody here is saying.   Now just need to ask the wife for the money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 11:43am
ask.....the wife??   whew!!
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 12:48pm
   You do realize the 1086 & 1486 were made before the 8030 ? The 88 series IH would have been the competition for the 8000's so it is not really an apples to apples comparison.
http://www.rumelyallis.com
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 5:12pm
Rfdeere, I'd take an 8000 series over an 88 series as well. And yes, I have logged alot of hours on an 8050 AC and an IH 5288.
