Model G
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: Model G
    Posted: 15 Jul 2023 at 6:12pm
   My  G sat for a couple of years,, started it and   had two dead cylinders, new spark plugs and wires but still two dead cylinders,  Did a compression  test, dry  80 to  100 lbs, wet test 100 to 125lbs on each cylinder.  What is the top compression on a new engine? What is the firing order of the engine?
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 6:50pm
are you sure you are getting fire to those cylinders?
#1 is in the rear of tractor at the belt end
firing order is 1-3-4-2
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2023 at 6:13pm
  Joe M [Ga]
        Turns out that when I replaced the plug wires I got  the firing order wrong, changed wires around to correct order  fired up on all cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2023 at 7:27pm
good deal!
Ford 345C TLB
Bill Long View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2023 at 3:04pm
Don't feel bad. Its a common mistake.
'Very unusual firing order
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2023 at 3:22pm
Good to see ya on here Bill!
Ford 345C TLB
