Brake Job almost done
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Brake Job almost done
    Posted: 30 Jun 2023 at 10:13pm
Garage Queen
starting to look more like a storage shelf than a tractor.
This weekend she'll be out.
Anti-seze is everyone's friend.
just don't get it on the brakes. 😀
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2023 at 8:24am
Very nice ! Thanks for the pics !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2023 at 2:26pm
Anti-sieze is the best thing since Italian bread.  Lookin' good Benny!!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2023 at 5:58pm
bought this tractor with lots of issues.
But we're working them out.
Bolts missing EVERYWERE !!!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2023 at 7:22pm
One of the nice things about anti-seize is that you remember you used it for hours when you look at your hands. Messiest stuff ever!!!
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2023 at 9:51pm
Thanks for keeping another A-C alive and kicking, it is appreciated!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2023 at 3:01pm
Sounds like a "lightweight" Benny!.....
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2023 at 3:18pm
Maintenance guys at the factory used to tell me this.
Anti-seeze keeps parts from freezing together. It's not a lubricant.
Anti-sieze has metallic flakes in it and will create increased wear if used on pivot points.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2023 at 3:44pm
My thoughts...anti-seize is great for a lot of things, but brakes isn't one of them! Dry, dry, dry...that's what it needs to be in that area...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2023 at 4:20pm
antiseize is on the adjustment threads .
Silly Boy !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2023 at 7:18pm
How much air-gap do you have between the disc lining and the metal rubbing surface ?? I like to get it down tight, like .020" to .025".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2023 at 8:28pm
shimed it on the loose end of the spec.
cause that was the shims I had. Figured .005 was close enough.
seeing you have .150 worth of wear material before you get to rivets. And we all know how good those rivets will stop you. :-)))
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2023 at 8:41pm
So, you are more than .040" air gap ??
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2023 at 10:50pm
Excuse me, Ben...whatever you think...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2023 at 12:15am
brakes work FANTASTIC and ill be able to adjust the brake rod in 5, 10 , 20 years, or probably as long as the tractor is around.
antiseze goes on threaded adjustment rod below the brake band and the discs.
I've got another 17IV ready to go in the shop for left brake issue. Yep, brake adjustment rod is FROZEN and can't get pedals even....
Edited by Macon Rounds - 04 Jul 2023 at 12:28am
This page was generated in 0.045 seconds.
