7000 series clutch cables
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: 7000 series clutch cables
    Posted: 08 Apr 2023 at 8:54pm
I know depending on the chore of the tractor but how long are people getting use out of there clutch cables before they are stretched  beyond use or before they break?  last one maybe has a yr and a half on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2023 at 8:59pm
Don't know your specifics, but 15 to 20 years on many used in the field.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2023 at 9:03pm
I have one an a 7040 that we round bale with starting and stopping its a year and a half old streched  out with and a 7080 used as a loader tractor just broke tonight
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2023 at 9:19pm
And you're absolutely sure the 7040 cable is stretched ?? I'd bet the brass bushings on the valve fork are broken. The 7080 was new 18 months ago too ?? Where did you buy the cables new ??
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 7:57am
The no cab 7000 series tractors didn't use a clutch cable. They had a very simple rod linkage that was easy to use and didn't stretch or wear out. Pedal effort was minimal compared to a cable that gets dry and stiff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 8:07am
bought them from my agco dealer.  The 7040 has had at least 3 cables replaced since Ive had it maybe 13 yrs and the 80  that I havnt had very long just broke last night.  How do I look up the bushing on the forks your talking about?
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 9:35am
I've never done one.
And I have a lot of Allis.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 10:51am
Two- 70269529 bushings. I usually replace both upper and lower ball joints  which are 70930435 and their grade 8 bolts. Oil the snot out of everything that moves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 11:47am
ok thank you
