G starter dragging
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: G starter dragging
    Posted: 29 Jan 2023 at 1:15pm
I’m gonna have to get it rebuilt. It just turns too slow. I put on cheap jumper cables from a 12 bolt and it still wasn’t fast enough.
I undid the ignition wire and jumper Ed it to the 6 volt battery and then put a 12 volt battery to the starter and it starts but still doesn’t crank very fast.
I pulled the starter and blew it out. It liooks nice and clean. I wire brushed where it bolts to the tractor and wire brushes the bell housing where it bolts up. I removed the battery box and cleaned and wire brushed the mounts and where it bolts up.
Brand new battery and brand new cables.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2023 at 3:29pm
Send it over to Steve at B&B.  He'll fix it up so it spins that 'G' right over!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2023 at 9:11pm
Thad, sounds like that ole' girl needs an Armature in it. I can rebuild it for ya if interested. Thanks Phil for the Kudos!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 6:46am
Steve@B&B
Steve I was hoping you’d see this. I have it up for sale and a couple guys very interested. I’ll have to explain the situation to them.
Can you PM me a price and a guess on the shipping to North West Arkansas?
I was concerned that parts may be hard to come by these days?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 7:37am
Thad, sent ya a PM....
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 5:28pm
Check the ring gear to make sure it isn't worn.  With new gears on a rebuilt starter, a worn ring gear will wear down those starter gears pretty quick!
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 6:17am
You stated you put on new Cables. Reminder..... Those cables need to be as thick as Goucho's Cigar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 7:16am
they’re very heavy and no longer than necessary.
I also used different cables to run a 12 volt battery to it. It still turned slow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 7:18am
The teeth appeared good when I had the starter out. I even felt the back side to feel for any bad spots I couldn’t see.
