Where’s does a G ground cable bolt to the tracto |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9733 |
Topic: Where’s does a G ground cable bolt to the tractoPosted: 27 Jan 2023 at 5:18am |
Mine has a very small cable hooked to the battery box.
I’d like to make this right. It never turned over very good. |
tomNE
Joined: 13 Sep 2009 Location: dorchester, ne Points: 1225 |
Posted: 27 Jan 2023 at 8:37am |
this observation has nothing to do with a G. I've always found grounding back to the engine block with the correct sized ground cable or bigger, helps starters work up to factory standards!
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4942 |
Posted: 27 Jan 2023 at 11:13am |
Thad, it mounts to the front box mounting bolt, a good #1 or a heavy braided cable is needed. A good clean connection to the mount and to the shifter plate is also needed. I usually add another cable from the back side of the bracket to the starter mounting bolt just to guarantee a good ground. ![]() ![]() Edited by JoeM(GA) - 27 Jan 2023 at 11:22am |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 27 Jan 2023 at 2:32pm |
X2!
