R76 Gleaner accelerator roll drive |
Gary(WI)
Topic: R76 Gleaner accelerator roll drivePosted: 19 Oct 2022 at 6:46am |
I have an r76 that we put new drive gears on before beans and the gears are worn out already Anyone have an ideas Thanks
MACK
Posted: 19 Oct 2022 at 6:54am |
Are the rollers in time? MACK
Unit3
Posted: 19 Oct 2022 at 7:54am |
Timing would be the first and only thing to come to my mind.
DrAllis
Posted: 19 Oct 2022 at 8:10am |
Never done one that new but, I do remember loosening the three bolts on each accelerator roll bearing flanges and positioning the roll shafts such that the gear lash wasn't tight, but also wasn't wide/loose. If you have had a failure of teeth, I'd imagine those shafts have been spread apart and the lash may be pretty sloppy, which could lead to early failures.
JPG AUSTRALIA
Posted: 19 Oct 2022 at 9:27pm |
Those teeth are very hard,they take thousands of hours wear,the only time i see them fail is if something goes through the rollers,like a piece of steel or stone,and then a tooth or two will be sheared. Otherwise maybe your rollers aren’t timed and are fouling causing damage.
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1014 |
Posted: 20 Oct 2022 at 5:29am |
Check timing first. Then gear lash. Could be a bent shaft but you can see that in the gear lash also. Could also be a bearing. Had a 62 one time that had a key way messed up.
