D10-12 radiator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D10-12 radiator?
    Posted: 02 Oct 2022 at 9:44pm
Has anyone had any luck with the new reproduction radiators for a D10-12? I am not sure there is a radiator repair shop open around here anymore. Thanks, Tracy
Aaron W in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron W in NC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 9:17am
I replaced the radiator in my 1965 D10 with an aftermarket I think I got it from Amazon. It works well, fit was ok, had to tweek the sheet metal a little to get it to fit. Cost to recore the original in my area was way to expensive.
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 9:43am
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 10:59am
I bought a new one for my WD45 12 years ago. The overflow tube was wrong. I had to cut a slot in the shell to make room. The new one just had a spot on the neck to connect a rubber hose to instead of the original smaller steel line. So pay attention to that.
Edited by Allis dave - 03 Oct 2022 at 11:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 7:02pm
I will try to get mine fixed. Called a couple of places said they could re-core it. We will see when I get time to get it off. Thanks, Tracy
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 8:27pm
I had a D15 radiator recored by Rock Valley tractor years ago.
I bought an aftermarket radiator for my D14, and I had to cut the fan opening. It was diamond shaped not round.
Not much help on a D10 or D12 other than I think you are hit and miss on a reproduction
I'd go to YTMAG or Steiner's If I bought one. I tried to find the best deal on my D14, and it wasn't a deal. It did work though.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
