WD45 seat with a back rest
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: WD45 seat with a back rest
    Posted: 27 Sep 2022 at 3:50pm
Can anyone recommend a good replacement high back seat for a ‘45? I have a Tractor Supply seat on my CA but seat sits too high. Don’t want such on the 45. Dana
Blue Skies and Tail Winds
                          Dana
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 4:41pm
I have one that works fairly well for me.  Unfortunately, I don't know where it came from and I've had it for 15 years.  It is a high back with hinged armrests.  U.S. made according to a sticker.  Previous owner had it mounted on a steel plate.  Because of offset steering wheel it was centered which to me was too far to the right so I had the plate re-drilled and move to the left 2 or 3 inches, not centered on the wheel but gives a little more room by the fender.  I'm going on memory and will see the tractor tomorrow to confirm.  You obviously can't use the flip hinge arrangement with this set-up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 8:42pm
I think I'd first re-engineer the seat linkage. That curved flat iron that the hinge is on would get changed to straight back level and then straight up to where the seat would be. Then, a spring/shock down to the platform. This would eliminate stepping over the suspension getting on and off. I'd be happy with a D-17 deluxe seat with no armrests. Left armrest would have to flip up to get on and out of seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2022 at 4:44am
Wow Doc there’s thinking outside the box. Thanks Dennis. I’d sure like to see pics of both of your ideas. Anyone have any pics to share? Surely someone has seen/done something along with Docs ideas. Dana
Edited by captaindana - 28 Sep 2022 at 4:51am
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2022 at 7:27am
And, while you're at it, weld a 1 inch strap across the front edge of the right footrest to hold the brake pedals ahead a little farther. This creates more room for your right foot if you have big feet. Readjust brake rods to compensate for new position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2022 at 5:20pm
Doc sounds good for my size 14’s😁
                          Dana
