AC 6060 on Round Baler
ACkojack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACkojack Quote  Post ReplyReply Direct Link To This Post Topic: AC 6060 on Round Baler
    Posted: 16 Aug 2022 at 9:54pm
Checking if anyone has ever used a 6060 on a round baler. My two neighbors who used to bale for me no longer do custom work . Most of the posts on other tractor forums say 65 HP enough power but tractor weight big issue  My 6060 has FWA and I think it weighs around 7500 lbs (not counting 500 lb weights on front). Other option would be to bite the bullet and look for a 200 or 7000 for more hp
Tom59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom59 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2022 at 10:10pm
What model baler and size bale are you thinking of using behind your AC 6060 tractor ?
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2022 at 10:26pm
4x4 baler would work on 65 hp tractor. On my JD 467, I would not want anything less than 90hp especially on hills. 190xt is a good match, assuming you can mount a bale monitor.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2022 at 11:51pm
We baled 25+ years with our AC180 / 185's on a vermeer 605C and later 605F baler.  We're in the Loess hills of west central Iowa, no issue on power or weight. The 6060 is a little less HP but about the same weight, unless the FWA adds more. You may need to add weight to rears if it doesn't have some already.
Our 18.4x 28 tires carry 1150 lbs fluid in each tire, according to local tireman. A 180 tractor w/ fluid about 7700 lbs. The 185 had no fluid but 3 F & H weights on each side, we've never weighed it.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 2:42am
Our 180 weighed about 8500 lbs. with 18.4 x 28 tires full of CaCl. the first time I pulled it.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 6:26am
Neighbor uses a 6070 on a large NH Round Baler. I think it is a 5x5.
It has the 18.4x28 tires so it would basically be the same dims as a 6060.
It is 2wd.
He prefers that over the 8030 he has running that baler.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACkojack Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 6:34am
looking at 4 x 5 baler something like a vermeer 504
I’m not worried about weight just don’t want to burn up anything due to inadequate HP
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 6:36am
Just like a plow. Pulling too hard?? shift down a gear.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 6:47am
Pulling a round baler doing dry hay does not take tons of  PTO HP.  If it is taking tons of HP, you're tractor is bogging down, etc., slow down a little!  We've been round baling hay with around 65 - 70 HP on a few different tractors for over 30 years.  No PTO issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom59 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 6:08am
I think you will have no problem handling a 4x5 Vermeer round baler behind your 6060 even on hills, specially if you just doing dry hay. The PTO horsepower requirement on most 4x5 balers is usually 45 PTO horsepower, so your AC 6060 should be good.
msmith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote msmith Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 7:45am
You'll be fine. I pull a 504 signature with a NH Powerstar 75. Approximately 62 PTO hp.
I baled 4x4s with a NH pulling it with a Ford 3930 FWD (45 PTO hp) on some very steep hillsides.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACkojack Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 8:24am
anyone bale with a New Holland 640? I see one at local auction but likely requires more hp than Vermeer 504
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 11:00am
I don't see what the big deal is. . . . .No, I've never used a NH 640, but so what?  They all do pretty much the same thing!  IF you aren't doing silage bales, IF you aren't using crop cutters, IF you aren't trying to schitt out a 1000 lb bale every 50 seconds, IF you don't drive like Mario Andretti on the hills, Imma bet you can make it work just fine!  How much hay are you planning to make?  IDK, maybe this thing packs super tight, but still, even that's adjustable?  No??
shamrock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shamrock Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 7:29pm
I have a New Holland 848 chain baler, i use my 170 and my 6060 both run it just fine no issues at all. Like Doc said grab a lower gear, the 6060's got'em.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 8:55pm
I run an 849 New Holland with my 6060 and it does fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACkojack Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 9:24pm
I wouldn’t even dream of trying to bale silage with a 6060
I’m looking at around 50 to 75 bales a year
If I’m doing balage I, would hire that out to a bigger setup but he’s a ways away and have to make it worth his while
Appreciate all the tips
This page was generated in 0.150 seconds.
