water temp gauge 101
jeickman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Topic: water temp gauge 101
    Posted: 15 Jul 2022 at 4:52pm
So I have removed the instrument cluster on my D17 III and replaced all the gauges.  Guess I didn't do a good enough job of photographing the all the back side wiring connections.  Temp gauge is not reading.  Is there a hot lead that needs to be connected to one of the terminals?  Don't see this in any wiring diagram in the I & T manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 5:06pm
You won't find the wiring diagram showing the temp gauge because it isn't electric. All D-17 tractors used a mechanical gauge with a mercury filled bulb.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 9:07pm
x2!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2022 at 9:14am
Thanks for quick help on this.  When I cut the lead on the old one i thought it was copper wire but I now see that it is a capillary tube.  I don't think that I kinked this on the new one and I know that the bulb on the new one is in contact with the coolant so I must have a bad gauge right out of the box.  Wanted to use a repro with the Allis Chalmers labeling but may have to resort to a higher quality aftermarket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2022 at 2:02pm
AGCO gauge isn’t that much more expensive and it’s a good quality gauge. Most aftermarket gauges don’t always look original and there is nothing worse than a gauge that not only reads incorrectly but also looks incorrect. My D17 I recently purchased has a auto temperature gauge and I can’t wait to get rid of it for both of those reasons. New AGCO gauge is ready waiting to be installed after a paint job.
This page was generated in 0.191 seconds.
