Trans Noise |
gmk5150
Topic: Trans NoisePosted: 25 May 2022 at 9:38pm |
I have a 1938 ac B
To i replace oil seal on left axle...replaced as i took it apart Now trans has noise grinding....Tractor ran perfect before And idea what i may have done WRONG ty ray
juniorp53
Joined: 16 Mar 2012 Location: United States Points: 53 |
Posted: 26 May 2022 at 11:26am |
which seal exactly did you replace ? the one behind the drum , at wheel hub or the one at differential
i am gonna guess you mistakened a shim for a gasket
gmk5150
Posted: 26 May 2022 at 6:11pm |
changed seal at end axle inside trans i used same shims i took off (2) thank u sir
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90838 |
Posted: 26 May 2022 at 6:46pm |
that does seem odd... As you remove the carrier, the differential will drop a little... but when you reinstall, the carrier should slide back up into alignment.. Normally as long as you retain the original shims, you have no problem.... Backlash and preload should remain the same..
gmk5150
Posted: 28 May 2022 at 6:59pm |
yes i put every back as i took out 2 shim used diff race cover though..to day i took shims out..SAME NOISE as before...im confused
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2048 |
Posted: 29 May 2022 at 6:38am |
Where in "mn" are you located?
http://lonsallischalmers.com
steve(ill)
Posted: 29 May 2022 at 8:55am |
you can not change the bearing housing, bearing race, or shims and just assume everything is right.... The shims changed the bearing preload and backlash in the gears. Every housing / bearing will be slightly different in dimension and require a specific shim pack..... You need to take a couple measurements..
gmk5150
Posted: 29 May 2022 at 9:38am |
oh my..can i ask how i take measurements..im far from mechanic 🤠thank u kindly for assistance ray
steve(ill)
Posted: 29 May 2022 at 9:47am |
the purpose of the shims is to take up and SIDE TO SIDE clearance or movement of the shaft.... You normally check that when the PTO housing is off.............. I think what i would do now is start with and extra shim or two and tighten the cap... then you need to PUSH or jack the differential shaft IN and OUT and see how much it move with a MIKE... If it moves .005 inch, then i would take out .005 inch so you basically have ZERO clearance.... If you put in a .010 inch shim and you have .001 endshake, then you were .009 TOO TIGHT to start with..... TIGHT or LOOSE will give you a noise.
Going to be hard to check backlash in the gears, but that should not have changed much if you still have the right bearing PRELOAD..
steve(ill)
Thanks(1)
Posted: 29 May 2022 at 9:53am |
the book recommends to remove BOTH final drives to do the inspcetion... and the PTO housing... but what you are looking for is SIDE MOVEMENT, if you can do that with the housing in place. ??
gmk5150
Posted: 29 May 2022 at 8:08pm |
ty steve kinda of u i try that im 80 i move slow 🤠im in oak grove Mn
steve(ill)
Posted: 29 May 2022 at 8:37pm |
what you might do is put the bearing retainer on without shims and just "SNUG" up the bolts so there is zero bearing clearance, but not bend the retainer.. It will be setting out a little from the transmisison housing.. measure the GAP between the retainer and the trans housing... then disassemble and add shims to fill that gap.. Since your torqueing the bolts TIGHT after install, you might add an extra .001 or 2 shim pack...... That might be about the best your going to do... at least you would have a MEASUREMENT to compare to what shims you are adding right now to see if you were TIGHT or REAL TIGHT ???
Lon(MN)
Posted: 30 May 2022 at 6:38am |
You are ten miles from me. 763-241-9679. I have several of these apart. I am a show and tell person.
gmk5150
Posted: 30 May 2022 at 8:15am |
Omg ty ty I try again if I fail I call ray 7632862335
gmk5150
Posted: 31 May 2022 at 11:10am |
omg i mght give up...wife says burn it....shimmed it few times Failed 😩
juniorp53
Posted: 31 May 2022 at 7:14pm |
what wrong with your original diff race cover? usable ? assuming you left it as was when you got it out ... grab a new seal off ebay pound old seal out of your orignal cover with hammer+ screwdriver and gently pound new one in with a wooden dowel. I think it should be a national oil seal #450444 then put it back in as you found it when you started
seal should be like $15 if your 80 and made it this far id say your doing pretty good!! |
gmk5150
Posted: 31 May 2022 at 10:15pm |
ty no issue with seal i replaced after all back together....grinding noise... thinking it cover with race in it...tried diff shims but no luck Ty for help
gmk5150
Posted: 31 May 2022 at 10:16pm |
first race cover i broke tighting ðŸ¤
gmk5150
Posted: 01 Jun 2022 at 9:21am |
its cover and race at end of axle is giving me issues ty ty
steve(ill)
Posted: 01 Jun 2022 at 12:22pm |
sorry Ray... we cant see the bearing / cover to give you any better advice.. You said the original cover BROKEN when tightening ? Maybe it was in a bind and put a DING in the bearing / or race something on the bevel shaft.... Dont know what else we can do to help at this point.
gmk5150
Posted: 01 Jun 2022 at 12:37pm |
thank u kindlly think i give up sell dam thing...lol
steve(ill)
Posted: 01 Jun 2022 at 3:19pm |
there are a LOT of Bs that "make noise"... As long as you have plenty of shims and the bearing is not TOO TIGHT, you might be able to run it for YEARS with a noise. ??
unless the noise sounds like it grinding corn ! ![]() Edited by steve(ill) - 01 Jun 2022 at 3:19pm |
gmk5150
Posted: 01 Jun 2022 at 3:37pm |
Ty for help
