D21, 210, 220 Rear Axle Diameter;
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Topic: D21, 210, 220 Rear Axle Diameter;
    Posted: 26 Apr 2022 at 12:11am
Asking a question; Are the rear axles on D21 / 210 / 220 the same 3.25" diameter as on a 200 ?
 IF yes are the wedges and cast wheels interchangeable? I've a cracked rear wedge and my renter thinks he know where a D21 or 210 parts tractor may be setting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 6:11am
D-21 and 200 and 190/190XT above s/n 9001 are the same 3.25" axle diameter.   210/220 are 3 5/8" and use a different two-piece clamp.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 7:53am
7000 tractor also uses 3.25 axles, and many came with 38's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 10:39pm
Dr Allis and Inj Ed thanks to both of you for the answers.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2022 at 2:44pm
And don't forget about some D21's had a rearend transplant from the 210 tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2022 at 4:04pm
?????    There were many D-21 rear ends that got 210/220 ring and pinion gear sets installed (in a D-21 rear end housing) to increase the speeds 10%, but only on pulling tractors. I don't know what else you would be referring to, as a 210/220 rear end assembly would lengthen the wheelbase on a D-21 by maybe 4 to 5 inches ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2022 at 4:20pm
Yea, there's a few around, you can tell by the rear tire and fender curve don't match up right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2022 at 12:55am
Drove down to look at tractor. It's a 200 bare back, 3 bad tires but all parts still on it.. IF new owner of this farm will sell the  tractor I plan to make offer & maybe drag it home for parts.
 They bought the farm from an estate about 3 years ago tractor and few old implements setting in buildings. THey haven't cleaned building site yet, took out all fences and 2 large piles of trees.
