Flat washer on my governor shaft ?
ac55tractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac55tractor Quote  Post ReplyReply Direct Link To This Post Topic: Flat washer on my governor shaft ?
    Posted: 23 Apr 2022 at 9:44pm
Hi to all.
    When I disassembled my A/C-B engine, I found a hardened flat washer on the on the outboard side of the thrust bearing on the governor shaft. It is a distributor type ignition. The parts manual does not show one there. I can only guess that it was acting as a limiter for the thrust bearing on the governor. Does anyone in the forum know of any reason why someone would add a washer there? I was considering leaving it off.
Any thoughts on this would be helpful. Sorry no pictures.
Thanks
Steve (in ME.)
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2022 at 6:40am
Maybe to take up some 'slop' from wear ??
Lotta B guys here, they'll KNOW for sure !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2022 at 3:27pm
Probably someone that had never worked on a B Allis Chalmers before. The angle that is cut in the gears keeps it pushed rearward as the engine is running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac55tractor Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2022 at 3:51pm
Thanks for the help. Sounds like it's nothing to be too concerned about. As if it was a spare part that someone found, and a place to install it.
Steve
CWiltfong2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CWiltfong2 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2022 at 4:48pm
I have a "B" with a magneto that would occasionally jump time at idle or shut down. There was enough slop in the governor drive that allowed the magneto to disconnect. I used brass washers to stop the excessive travel and it runs fine. I had bought the tractor non-running and that is what turned out to be the issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac55tractor Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2022 at 5:02pm
Thank you for your reply. That was a good find for you. I will keep that in mind when I fire up. Thumbs Up
