D17 power steering Ram Cylinder
Newmama552 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newmama552 Quote  Post ReplyReply Direct Link To This Post Topic: D17 power steering Ram Cylinder
    Posted: 12 Apr 2022 at 1:06pm
I bought a D17 last fall used it for a day and it started leaking power steering fluid. Thought I had it fixed and then it started to spray fluid out of the cylinder when I turn the steering wheel. Fixable or do I need to find a new part?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2022 at 1:15pm
"MOST" small cylinders come apart.......... and the thing that goes WRONG is the VEE rubber seals is piston seals.. They can be replaced.... 2-3 different ways those small cylinders are made on the head removal / disassemble........... I have not done a D17.... just did a CASE 530 last year.. Worked great !
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2022 at 1:21pm
https://www.youtube.com/watch?v=EOp7PSx7cAc
is this what it looks like ?  Maybe i am way off base .
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2022 at 4:54pm
where is it spraying from the PS cylinder or ram ?
If it's between the endcap and cylinder tube, it's probably the o'ring seal.
There's another o'ring where the cylinder bolts to the front casting, but it's not under pressure.
Other causes;
Might be a cracked cylinder tube.
Loose or stripped fitting at the rear where the line screws on.
@steve(ill) , yep that's the one.  I'd hate to pay that guy an hourly wage.
BTW, no need to remove the rack from the piston rod; that is ONE HEAVY press-fit.
Edited by Gatz in NE - 12 Apr 2022 at 4:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2022 at 5:01pm
I have a good used cylinder with the rack I would sell if you need one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newmama552 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 12:30pm
It is spraying from the end of the cylinder
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 12:47pm
so the cylinder is CRACKED ?
