Rear axle seal leak on 6060
Rafterg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Topic: Rear axle seal leak on 6060
    Posted: 03 Apr 2022 at 7:46am
My 6060 rear axle just started leaking. I have read the repair manual and it looks as all I have to do is unbolt axle housing and then disassemble the axle from the housing. Just want to make sure when I slide this out, nothing drops down in the rear end.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2022 at 7:59pm
Nope.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2022 at 10:49am
I have also found that putting to much grease in the fitting at the end of the axle shaft will mess up the seals and cause them to leak.
one of the guys in the shop over greased at the service and the next morning there's a puddle of oil under both axles.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2022 at 11:54am
I have replaced them on JD but just making sure nothing would fall down in the rear end when I took the axle housing off.  I just split the tractor to but a new driveshaft in that broke and don't have five hours on it since doing that work.
We have detected instance of bullying in this message/comment.
The person you are writing to might feel bullied. Maybe you should avoid sending messages like this.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2022 at 12:06pm
I have replaced one on my 6060 at about 9000hrs.
Make sure your vent underneath the seat is clear, mine was plugged
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2022 at 6:18pm
Can you please explain the being bullied part ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2022 at 5:31pm
I need to check that, I have noticed the last few times that when I check the oil, there is a significant amount of pressure on the plug with the dipstick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2022 at 5:32pm
I am not sure, every time I reply, this is added to my post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 7:44am
So I am trying to locate the vent under the cab, I can see it in the book, but does it run up into the cab somewhere or does it just vent under the cab.  Sorry for all the questions but just can't seem to locate it.
John m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 8:19am
More than likely just a square pipe plug looking thing that has a hole in packed with a small baffle. That's what my 190 vent plugs are.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2022 at 7:35pm
If you lift the entire seat assembly up from the floor it is right there in the hole the seat base left i the floor.  If i remember right, its a little tin  crimped on cap type.  I have had to unplug mine a couple times  each time the axle seals quit leaking after i did that
