I600 hydraulic oil capacity
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: I600 hydraulic oil capacity
    Posted: 16 Mar 2022 at 6:01am
I need to change the hydraulic oil on my new to me I600 backhoe.
I need to know how much oil to buy?
I plan to drain the loader frame reservoir and the transmission reservoir.
Are they separate of each other? Can they use the same type of hydraulic oul?
Thank you in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2022 at 8:48am
Thad, im not much help, but our CASE 530 hoe/ loader has the frame full of oil. It takes about 10 gallons of universal tractor fluid....... The transmission is just like a farm tractor. Not part of the hydraulic system. I dont remember, but probably around 4 gallons, and it is the same universal fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2022 at 6:32pm
That, book says 5W20 ND for PS system.  Can't say how much, but a gallon or so would be my guess...
As for the hyd, any good universal hytran should do the trick!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2022 at 7:14pm
Dave on this one the hydraulic reservoir from the loader is plumbed in to the power steering fill on the front end
