7060 with 630 JD disk 28-30 foot
Boyd122 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boyd122 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 with 630 JD disk 28-30 foot
    Posted: 21 Feb 2022 at 9:16pm
Looking to buy a local disk from a dealer, it’s a 630 JD disk I believe it to be 26-30 foot wide with guide wheels.
How hard will it work my 7060? I’d like to try it but if it won’t I have a different tractor I can pull it with. I am not sure what my tractor dynos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2022 at 9:37pm
An A-C 2500 disc that is 25ft wide works well on a 7060 with matching 20.8 x 38 tires/duals with fluid in inside tires. A 2500 disc has 22 inch blades with 9 inch spacing between blades. Weight is approx 120 lbs per blade. What specs is a Deere 630 disc?? I can find you a 15 ft disc that will stop your tractor dead in its tracks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boyd122 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2022 at 9:56pm
I’m pretty sure it’s on 9 inch spacing and has 22 inch blades. I’m not sure on the weight of it however. I have two sets of weights on both sides with water in the tires also with duals. I’ve got a subsoiler that’ll make my Allis scream uncle but I don’t want to break it
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2022 at 11:08pm
We just put new blades on our 24' 630. It has narrow spaced blades. It is all a 7060 really wants in wet or heavy ground. Finish working dry ground is fine but in our soils I wouldn't try bigger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boyd122 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2022 at 11:43pm
I’ll have to measure it again, I’m not exactly sure on the size of the disc. I assume it’s a 28-30. May possibly be 26ft and if so that may be a little be more better for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2022 at 7:33am
I would rather have a 22 or 24 behind it.                   MACK
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2022 at 8:08am
Seems most people pull a disk a little to large for there tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2022 at 6:29pm
Id rather make a few more passes than pull the guts out of tractor,
