tach hook up in magneto
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: tach hook up in magneto
    Posted: 12 Jan 2022 at 10:18am
my wd has wico mag and i have a little 2" 3000 rpm distributer coil ingition tach  thought i would mount it by the traction booster gauge.  can i hook the the green tach wire to the coil or points ?   dont need the tach as we know where 540 is on the quadrant and been on the tractor for fifty years but have the need to mess around some
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2022 at 11:38am
You'll need a tachometer specially made for a magneto unless you have a mechanical tach. One for a distributer will not work.  I have a 6 cyl magneto tach, so I know they are out there.  Westach will make just about any gauge you desire, for a price.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2022 at 11:39am
This will be intresting hear, I would think it would act act as grounding to the points.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2022 at 6:43pm
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2022 at 6:54pm
Steve we put one of those cheep tacs you showed a picture of on the saw mill arbor shaft at our tractor clubs saw mill and it works great.   The saw on the mill is hammered to run at 600 RPM's .  We mounted the readout so spectators can't see it .  We have used it for two years with no problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2022 at 10:11pm
This guy had an airplane with magnetos (I think) and he got a tach to work.
Here is the weblink
http://www.bowersflybaby.com/tech/tach.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2022 at 11:06pm
can you get inside and hook it to the generating rotor side of the coil
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2022 at 5:15am
I have small engine tachometer/hour meters on my Honda inverter generators that we use for the RV. They have a battery for power and mount over the spark plug wire to get an impulse. I think one of these would work with a tactor magneto, but I have no idea how you would hook up the mag you already have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2022 at 6:12am
The one we used on the saw mill has a small magnet that we super glued to the arbor shaft and the pickup head is mounted so as the shaft rotates the magnet passes within 1/4 inch of it.   All this I think would fit inside the bell housing with magnet mounted to back side of pressure plate, or better yet on crankshaft pulley up front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2022 at 9:40am
we allready have dozons other tachs around the shop magnetic , ones you wrap the wire on the spark plug wire tiny tach ii we sell here.  i just want to do somthing differant
