Off topic Ford 172 cubic inch engine
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: Off topic Ford 172 cubic inch engine
    Posted: 09 Jan 2022 at 12:42pm
I worked on this fellows Allis equipment. Last summer he bought an 801 tractor. Used it for awhile then the drive shaft for the oil pump broke. The pump locked up, twisted the shaft until it broke. Along with the rebuild I bought a new oil pump and a pump drive shaft from Steiner. The new shaft is a little shorter and comes with a pin that fits in the end of the shaft. I can't figure out what this pin is for. Your thoughts?
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 12:45pm
dont know....does the pin ride against the mating shaft to keep the SHORT drive shaft from falling off ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 12:54pm
The pin comes uninstalled. The old shaft had a spring clip on one end to keep it in the oil pump so when you removed the distributor the shaft would not fall out. By the way the distributor drives the pump. Should have been the other way around. That would have saved the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2022 at 3:15pm
I'd look in the service manual for the answer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2022 at 6:54am
The service manuel shows nothing. My go to old timers for Ford are dead.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2022 at 2:19pm
Call Steiner. They made it different, so they should be able to explain.
Is the pump drive shaft really just 1/4" hex stock? Seems cheesy.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2022 at 3:52pm
The pin is to hold in place , Steiner did not make it different its a aftermarket shaft that they sale. Same as ones I buy from Reliance .
Edited by Fred in Pa - 10 Jan 2022 at 3:57pm
nonetheless ,still dead.
This page was generated in 0.085 seconds.
