Removing front axle assy 185
Bobjones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobjones Quote  Post ReplyReply Direct Link To This Post Topic: Removing front axle assy 185
    Posted: 17 Nov 2021 at 5:52pm
I want to drop the oil pan on my 185. I am starting to remove front axle assy for more room. I'm not sure about that front pin. does it go out the front or go towards to back? Is there a circlip holding that pin in place? Any help on this would be appreciated.
Regards, Bobjones
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2021 at 7:54pm
I was told to slide out the entire casting out of the front end not take the pin out.  Just have to make sure the frame rails are supported.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2021 at 9:16pm
The pin hole usually has a worn ridge to where pin won't come out. Removing front assy. Makes the job easier.                         MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2021 at 5:43pm
The pin comes out the rear.... If I remember right, there is a snap ring and then your thread a slide hammer in and hammer it out. When I worked at an AGCO Allis dealer we just rolled the front end forward as an assembly. I once did a 190 without removing the front end but it was very tight to get the pan out.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobjones Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2021 at 9:33pm
Thanks for the info. A slid hammer makes sense.
160 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 160 allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 11:56pm
To get the pan out of ours i took the 4 bolts out where the front axle frame bolts to the trans housing, took pan bolts out, jacked up passenger side of front axle and turned and slid the pan out from driver side. With the 4 bolts out of the front axle frame you can get enough room to get the pan out. It's tight but doable
This page was generated in 0.563 seconds.
