7020 Replacement Engine w/o intercooler
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: 7020 Replacement Engine w/o intercooler
    Posted: 28 Oct 2021 at 7:16am
Hi guys-My 7020 needs a new engine and a person has a 1800 hr non-intercooled 301 available.   This engine is probably out of a combine.
How hard is it to move the intercooler parts from my tractor over to the non-intercooled engine?
Please let me know your thoughts...thanks.
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2021 at 7:25am
What engine are you trying to buy??   In order to be even close to what you want to do, it needs to be 130 HP with a DM-4 injection pump from a 1977 or newer M2/L2 combine. Anything else is just a 301 and will be a lot more work.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2021 at 8:22am
301's are not the most expensive engines, nor complicated, to rebuild.  Unless the combine engine is super low hours and dirt cheap, it's hard to justify a swap.  Probably half the labor of the rebuild is just getting the engine out and stripped and accessories reassembed.  If the lower bores are eaten up, they can be bored and sleeved.
Hurst
1979 Allis Chalmers 7000
5800 Hours
