CA Air Filter Oil Cup |
rustyorange45
Silver Level Access
Joined: 01 Sep 2013 Location: Vernon Co. MO. Points: 416 |
Topic: CA Air Filter Oil CupPosted: 01 Oct 2021 at 9:44pm |
I have two CA tractors in need of the oil cup. The part number is 225857. Any help on replacements is greatly appreciated. Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1834 |
Posted: 02 Oct 2021 at 3:23am |
Just make sure that your replacement cup has the bevel on it or it will not clear the block. I bought one from a vendor that said it would work but it didn’t have the bevel and it will not work. Just trying to save you some trouble.
rustyorange45
Silver Level Access
Posted: 02 Oct 2021 at 7:11am |
The factory cup is 4 3/4 od and 4 7/16 id. I have seen the one that various vendors sell and it did not have the bevel, so l didn't buy one. One my cups is beat up pretty bad and the other has a rust hole in the bottom. I can probably fix the rusty one but if I can buy new I would.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4278 |
Posted: 02 Oct 2021 at 7:24am |
Pretty sure I have one off a tractor I parted out, central Ia. location.
ACCA52
Joined: 26 Jul 2021 Location: Grove City PA Points: 14 |
Posted: 04 Oct 2021 at 7:46pm |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 05 Oct 2021 at 7:01am |
Most of the oil bowls sold fit the early CA that uses the same small air cleaner as the B & C tractors that have the spring clips on the cup. I have not seen any aftermarket source for the larger CA and late B air cleaners with the screw clamp for the oil bowl. Good used or if your lucky, NOS may be your only options.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90826 |
Posted: 05 Oct 2021 at 8:35am |
you can buy either type at STEINER.. OLD CLIP or NEW CLAMP..
sparky
Posted: 05 Oct 2021 at 8:52am |
That’s good to know. When I was looking for one back a couple of years they only offered the clip style cup.
rustyorange45
Silver Level Access
Posted: 05 Oct 2021 at 10:03am |
None of the ones that Steiner carries is the right one for my air cleaner. They are to small and the one that is the right diameter does not have the beveled back.
steve(ill)
Posted: 05 Oct 2021 at 1:08pm |
There was a bigger cup used on the D10-12-14 that was 4-3/4... but it has straight walls on the outside...your saying yours is that OD size, but taper walls..?.. thats odd. Dont recall seeing any aftermarket like that.
rustyorange45
Silver Level Access
Posted: 05 Oct 2021 at 1:17pm |
My cup has a beveled back to clear the block I don't know if the straight walled cup will clear the block. Both of my CA tractors have the same cup, one is a 52 and the other is a 53.
Edited by rustyorange45 - 05 Oct 2021 at 1:20pm |
PaulB
Posted: 05 Oct 2021 at 1:19pm |
Those shown above are not correct for a CA with a clamp type cup. They will only work on the early CA that has the same small air cleaner as the early B the C and RC with the spring clips. The larger late model CA air cleaner has straight sides and a bevel to clear the block. The air cleaners on the D10/12 tractors are spaced out at the mount so that a straight sided cup works.
