wagon vs trailer
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: wagon vs trailer
    Posted: 22 Jul 2021 at 5:37am
Ok, I'm kinda bored and started to wunder.....
Say a tractor is rated to pull 3000#, could you pull more using a 4 wheel 'wagon' instead of a 2 wheeled 'trailer' ? To me a 'trailer' (1 or 2 axle) puts some of the weight on the tongue ,so backend of the tractor .. but a 'wagon' doesn't have any 'tongue' weight .
I've seen pics of tractors pulling 2-3 wagons of big bales,got be curious about load capacity of trailer vs wagon....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 5:50am
Any time you put downward force on the drawbar you are boosting the traction.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 6:59am
Pulling something like a wagon, yeah, you'll lose traction before you run out of power most likely.  Depends on so many things.  How fast are you going to pull it, what surface are you on, any slope, how much does your pulling vehicle weigh, and how quickly do you want to get it moving (acceleration) . Force = mass * acceleration.  I've pulled 120 square bales on a wagon with a 335cc  quad.  Don't make a habit of it, but I did it.  Get something with tongue weight, a lot of it, and you can draw  your tractor right down to stall without spinning.
Edited by Tbone95 - 22 Jul 2021 at 7:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 8:00am
just make sure you got the BRAKES for the load !
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 8:11am
The big issue with applying too much tongue weight would be draw bar rating. We have sheared a draw bar before with a fertilizer cart (guessing it was shock loaded). I would just guess that ~1200#’s would be around max weight for a 180-200 draw bar, then the 3 pt would handle up to 4000-5000#’s for optimum traction, heavier would need to be distributed over multiple wheels like a wagon.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 8:41am
If you should need to back up, a trailer is a lot easier.
Dusty
Luke114 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 10:36am
Sounds like an interesting math problem expressed with some differential equations including variables of mass, friction, traction, gravity, slope, beers consumed, etc.
My gut reaction is 4 wheel wagon for fairly flat and dry ground, trailer for conditions where traction is an issue.  And if you are pulling your hay wagon through the mud, traction may be the least of your worries! LOL
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 10:43am
I agree with Steve, its more for Braking safety (IMO)
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 3:28pm
Most trailers have brakes, most wagons don't.  Also, most wagons are not rated for higher speeds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 3:53pm
Im thinking pulling a 10,000 pound wagon down a hill with a 4000 pound tractor... TRACTOR better have brakes.
