8000 faster low range
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Topic: 8000 faster low range
    Posted: 11 Jul 2021 at 11:54am
In 85 Allis changed the low range was it for all the powershifts and all gears? What gears were changed and by how much? Is there a chart comparison. thanks for any info.
rieg
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 7:53pm
They changed the two gears that make LOW RANGE in the range transmission. They increased the speed 10% to 15%, or whatever it took to make 5th gear LOW range right at 6 MPH.  Nothing was changed in the Power Shift transmission. Only the range transmission. All six speeds in LOW range are 10 to 15% faster.
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 9:02pm
Thanks Doc. that's what I wanted to know. You hit the nail on the head as usual.
rieg
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 9:17pm
One with blue is pre gear change, one with silver is after. 8070 decals
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 9:36pm
This is the first I have EVER heard they had different colored decals. How cool is that? I only know that if you have one with 2nd high and 6th low at different speeds, 5th gear doesn't have the high pitch squeal that gets on my nerves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 9:52pm
I have decals made of the slower range if anyone needs them. More variations will becoming at somepoint. There are very minute differences in decals, that it's hard to keep straight. My decal shop thinks I'm a pain in the rear lol. The one of the faster gearing is in a 1985 8010, but they stuck a 8070 decal in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 10:01pm
8070 gearing gets a little confusing at times. Any 8070 FWA is 8050 gearing plus another 100 engine RPM (2400 instead of 2300). Any early 8070 2wd was slower because of the final drives, UNTIL very late models, which again got 8050 final drives.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 10:21pm
Ser # 2662 started faster finals....according to Norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 11:05pm
Lots of different speeds depending on models. Pictures give an idea of speed differences.
This page was generated in 0.087 seconds.
