D28X
OrangeTractorPower39 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeTractorPower39 Quote  Post ReplyReply Direct Link To This Post Topic: D28X
    Posted: 09 Jul 2021 at 8:19pm
I made a post a few days ago about my A/C model B serial numbers and casting numbers. (Thanks to all who answered my question!) But now I have a different question I was hoping somebody can answer for me. On the side of my engine block, next to the casting number is D28X, does anybody know what this means? Is it the date it was casted? I am stumped here and would like some clarification. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2021 at 9:14pm
Kaleb, in the last 20 years i dont ever remember that question coming up.  We have discussed the casting  AM numbers and the "cast date" , but no one has ever asked about D28X.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeTractorPower39 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2021 at 10:19pm
So you have never seen this before?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2021 at 9:08am
YES... every motor has a  similar number. I have no idea what it means. I have 5 tractors that are easy to get to so i read the number
AM 2916  27   E170
AM 2916 13    M16Z
AM 2916  27   F600
AM 2916  20    CL
AM 2916  17    A16Y
one odd thing is the "27" motors have the cast number upside down and under the freeeze plug, not above the plug..
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeTractorPower39 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2021 at 2:57pm
AM 2916  27   E170
AM 2916 13    M16Z
AM 2916  27   F600
AM 2916  20    CL
AM 2916  17    A16Y
Hm thats interesting, could they be put there from the dealership? If they are I'm not sure why a dealership would put that there or if they are allowed to.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2021 at 3:10pm
A dealership couldn't put casting numbers on things.  A number gets cast on a part when it is poured at the foundry.  A number or marking found on a casting, would have been incorporated with the pattern that was used in the foundry when the mold was formed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2021 at 3:33pm
Couldnt be done at a dealer- it was probably an experimental model of some sort from the factory
Edited by DougG - 10 Jul 2021 at 3:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2021 at 3:36pm
Not experimental... they ALL have it... it was CAST into the motor block from the factory.. Normally numbers are part number , date, manufacturing site, lot number, run number, design change ... hard to say what these numbers mean.
Could even be the number of the guy that setup the mold for the casting.
Edited by steve(ill) - 10 Jul 2021 at 3:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeTractorPower39 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2021 at 10:14pm
It looks like its stamped onto the block, not molded. But good point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeTractorPower39 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2021 at 10:16pm
I was thinking about lot number, I suppose it would make it easier finding the tractor that a person ordered. And it would also make sense of it being the guys number because it's different every tractor.
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 9:26am
   OK, here's my 2 cents worth. It's for foundry use only and a means of ID.Had no use to AC.
  It could be a date code or the ID of the pattern that the mold was made from. My money   is on a pattern ID that the molds were made from.
Edited by ACjack - 11 Jul 2021 at 9:31am
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 11:07am
"It looks like it is stamped onto the block, not molded."
Your picture clearly shows it is raised, if it was stamped it would be sunk into the metal, as the serial number is.  It was cast as part of the block.  There would have been a small tag, with that on it, attached to the pattern which was packed in sand to make the mold for the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeTractorPower39 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 9:46pm
Whoops, what I meant was it looks like it was put there after the block was casted. I looks like the D28X is on a small plate that was punched into the block. Kind of hard to explain.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 10:00pm
can you post a pic of the entire side view of the engine?  Thanks  Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 10:29pm
the numbers and letters are CAST into the block as it was poured, just like the AM2916 number ...... if it was STAMPED it would look like the tractor serial number by the shift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2021 at 5:36am
"Whoops, what I meant was it looks like it was put there after the block was casted. I looks like the D28X is on a small plate that was punched into the block. Kind of hard to explain."
Sorry if its not the answer you want, but its not hard to explain.  That is not a small plate punched into the after block was cast (for the record its cast, not casted).  Again that came from a tag that was attached (a small nail head impression is visible at each end of the tag) to the pattern used to make the mold that the block was cast in.  I worked at a foundry for a time.  The pattern makers put tags like that on them to identify different things as specified for an order.  It might be pattern number, date, lot, hard to say what that one is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2021 at 6:20am
But it sure ain't "stamped" !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeTractorPower39 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2021 at 9:37am
Oh ok, it looked like it was a tag that was nailed into the side or something. Thank you for clarifying it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeTractorPower39 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2021 at 9:38am
Yes I can, I'm going to the tractor later on today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2021 at 11:10am
Here are 4 different tractors with 3 different locations and three different size numbers... and one only has letters, no numbers..  All Model B tractors.
The AM2916 - xx  casting number is always the same... This "number" is random size, random, location, upside down, etc....Probably not real important.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2021 at 11:15am
the M16Z and A16Y are obviously TAGS that were set into the mold before the casting.. A couple of the others appear to be etched into the mold as there is no tag indentation.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2021 at 12:51pm
Wink Keeps life interesting to have mystery's to solve. LOL
From the few tid bits I know about case made parts, I know bigger casting need to cure. I was told engine blocks need 6 to 9 months to cure. Something about heating and cooling cycles of ambient air moves things a bit at first.Wink Or was somebody pulling my leg and filling with BS? Since I don't think they where, I got another. Hopefully Jim that or others that worked around casting can answer.
Do they let small parts cure for months as well?
My brain is giving me more, engine builder down the road told me about block curing. A bigger foundry like car companies need date code as they have acres of outside storage for curing engine blocks. By looking at date no question as to if the bloke has had time to cure or not before going in for machining.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeTractorPower39 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2021 at 1:18pm
The M16Z and A16Y are in the exact same place as my D28X.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeTractorPower39 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2021 at 1:19pm
It most certainly does keep life interesting!
