D17 Series IV Snap Couple to 3 point hitch conv.
Jesse175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jesse175 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV Snap Couple to 3 point hitch conv.
    Posted: 29 Jun 2021 at 9:03pm
I am converting my D17 Series IV from snap coupler to 3 point hitch.  I bought a 3 point hitch used from a 170 or 180 tractor and it appears complete.   My question is whether I should go ahead and hook up the tractor booster linkage or just bypass it.   I am not going to plow with it or pull anything extremely heavy.   I opted to go with a used donor 3 point vs. the cheap aftermarket ones that are available.   I paid $375 and it appears got a much better product.   Thing must weigh over 500 lbs.   I have a second question regarding what type of tool I need to remove the clips that secure the lift arms on their large diameter shafts.   Any other recommendation that can be offered for this conversion is welcome.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2021 at 9:12pm
You made a good choice. No need for TB linkage if not using for tillage. If you are referring to the slotted head bolts, there is a socket that fit them.                MACK
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 1:26am
I did the very same thing several years ago. As the clips, NAPA has a tool that removes them. It is commonly used to rebuild transmissions. I took a picture on my cell phone of the clips, walked in the store and 10 minutes later I walked out with the tool. I took an aftermarket 3 point off my series 4 and went to the factory unit. It is 100 times better than the aftermarket stuff. I wish I had done it 25 years earlier. I had to buy a short 1" drive air gun to remove the bolts underneath the tractor. I got 1 from Harbor Freight. You will love the 3point.
Edited by HD6GTOM - 30 Jun 2021 at 1:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jesse175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 1:51am
thanks for the advice.
