self unloading wagon/haywagon
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Topic: self unloading wagon/haywagon
    Posted: 28 May 2021 at 10:09am
hello ive seen videos of ac self unloading wagons double as haywagons... are they all that way? if so how do they work... not sure if mine opens in the back
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 4:46pm
Self unloading wagon? In what way?
Could it have been a New Holland Stackliner?
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 4:49pm
I think he is referring to silage wagons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 4:51pm
Ok, that would make sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 7:07pm
Do you mean stripping a silage wagon of the drag chains and front unloader? I guess it would work especially with a baler that has a kicker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 10:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 10:38pm
there is promo video of bailing into self un loading wagons then opening back up to unload hay by hand
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2021 at 6:48am
Well there you go, proof is in the picture. Actually a really good sales pitch, one wagon does both. Is that a D15 or a D17 pulling the baler? Looks like a series II D15 to me.
Edited by AC720Man - 29 May 2021 at 6:52am
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2021 at 7:32am
Not sure but I think that wagon has back doors that open and the apron reveres to move the bales out the back.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2021 at 5:39am
Exactly !
We had one that we used that way. If I remember correctly, you could only kick about 60 bales into it. Again IIRC, the back tailgate hinged near the top and there were prop rods on the sides to hold it open. The lags turned backward to slide the bales to the back.
This was our first self-unloading wagon. Up till then, we has used "false-front" wagons for silage and for bales. The false front was removed and all bales were unloaded out the front.
Hay was baled by an AC baler (302 or 303) with a bale thrower powered by a 8 hp. Briggs and Stratton engine.
Dad concluded that the self unloading was too small to be beneficial and that somebody was going to get hurt using it. It was also very hard (and unsafe) to unload. It also meant that you had to have a tractor with a PTO to unload and my grandfather's WF (which I now own) had no PTO. Ours was very short lived as a bale wagon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2021 at 7:25am
I have used my John Deere wagons without a roof a few times behind my baler. Works ok with a Deere pan thrower but the wagons do not hold many bales and are a little bit of a pain to unload. But when you had more hay than wagons and rain was coming it got the job done. I also use my wagons to pick ear corn into. Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2021 at 1:49pm
Here you go.........
Wondering how much hay you could do in a day? Would need at least 2 or 3 of them to keep the baler running....yes?
And is that a little Farmall running the hay elevator?
Biggest advantage I see to a hay wagon is if doing small runs, bales never hit the ground. If baled dry enough to not risk any mold, you ought to get it to the barn dry. But dealing with wagons seems like it would sure slow things down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2021 at 1:54pm
BTW, the video shows a couple hay elevator options inside the barn, which brings me back to a concept I once heard of called a "hay mow", which if I understood right, meant a big opening inside the barn filled with loose fill hay bales. Basically, they dropped in from above and were a jumbled up mess. Is that right?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 6:23am
Hay mows in barns around here are the elevated levels/floors (animals were usually on the lower level) hay was stored on.  Originally loose hay was put on the mows, in later years bales were piled on them.  Some did add conveyors, in the top of the barn, running the length of the barn with "dump offs" to feed bales onto the different mows.  Many piled the bales on the mows, some just dumped them, it depended on how much had to be stored as if the mow was open to the center aisle of the barn; bales would fall off the mow onto the floor before the mow was full when dumped and not piled.  In later years some put up large open buildings, hay barns with no mows, with conveyors hung in the top of the barn and just dumped the bales off the conveyors into big piles.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 11:12am
We used silage wagons for allis round bales. Had a new idea loader that pinned to the left front corner of the wagon it lifted the bales up and put in the wagon one guy stacked inside the wagon. Could get 122 bales in.
HOTSTUFF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HOTSTUFF Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2021 at 1:17pm
New member - parting out some of my Dad's (what I thought was..) less desirable AC collection. In process of selling His 2 beater, Self Unloading Wagon, Original, working. Descent shape, now I know maybe harder to find and great for a collection. What's going rate on a descent/working one nowadays, please?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2021 at 2:36pm
put a new post in the classified section. With pictures.
Any other allis stuff. Or unidentified orange stuff that could be ac
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2021 at 8:18pm
Still use hay mows here, much better dry storage for hay and a little more elbow grease because the bales get stacked in place. I use (3) barns and fill those first. Our ground holds moisture so a lot of waste when going that route even a few days causes loss.
Growing up, we used anything that bales could ride on as it beat picking them up by hand off the field. Most didn’t have money even when NH came out with stack wagons. I was really glad when the round Baler showed up at the farm for demo. My mother bought it for my father in 1980. Only pc of equipment she ever bought.
