D17 IV power steering pump
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: D17 IV power steering pump
    Posted: 23 May 2021 at 8:09pm
Got my D17 gas fired up and running after a recent paint job and what would be the proper way to get the power steering pump primed? I have the appropriate amount of fluid in it but it's not priming itself. Thanks in advance! Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 9:15pm
Steer it back and forth to end of travel.               MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 7:21am
If the pump has lost its prime, I guess I'd try to remove the top oil line, squirt as much oil into the pump hole as possible (be patient..take a couple of minutes) and quickly reconnect the line and fire the engine. Do it a couple of times if needed. A squirt can is what I'm thinking to get oil inside the pump and on the gears.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 5:45pm
Would loosening the pump outlet line a bit and putting air pressure (say 2 psi) via the sump fill line do the trick? Just one psi should lift the oil at least a couple feet which is about the differential height between the pump and sump. Engine running
Edited by Stan R - 24 May 2021 at 5:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2021 at 8:06pm
Moved the steering wheel back and forth until my arms tired. Attempted to fill the back of the pump with oil. Still nothing. I will attempt to fill all other hoses and see what happens. Ryan
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2021 at 8:38pm
Maybe the shaft seal in the pump went bad and it is sucking air?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2021 at 8:45pm
You didn't put a paper towel in suction line to keep it clean did you? I did, many years ago .                  MACK
This page was generated in 0.893 seconds.
