SAE 20 wt oil. |
Kruger
Topic: SAE 20 wt oil.Posted: 21 May 2021 at 12:30pm |
Checking the fluids in my D 17. Hydraulic is slightly low, service manual recommends SAE 20 oil, non detergent. I can't find it locally. Is there a viable substitute?
DrAllis
Posted: 21 May 2021 at 12:31pm |
MODERN DAY UNIVERSAL TRANS/HYDRAULIC FLUID...….
Kruger
Posted: 21 May 2021 at 12:53pm |
Thank you, can that be added to the present oil or should the old oil be drained and replaced. Appreciate your advice.
DrAllis
Posted: 21 May 2021 at 1:55pm |
If it was mine, it would get changed....every compartment.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89131 |
Posted: 21 May 2021 at 4:43pm |
Change it now and dont worry about it for another 10 years. UTF can be purchased at any Farm Store, Napa, Wal Mart, etc..
as Dr said... transmission, hydraulics, bevel gear... can all use the same. Edited by steve(ill) - 21 May 2021 at 4:44pm |
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5909 |
Posted: 21 May 2021 at 5:46pm |
He may have trouble locating the 'Bevel Gear' in his D-17. Perhaps you could give him some further advice. G |
DrAllis
Posted: 21 May 2021 at 7:36pm |
Power steering ahead of the radiator. Takes about 5 quarts. Fill just above the steering gear. Overfilling will vomit out the excess. Drain plug on the right rear corner underneath. Takes 1 1/8" wrench. Hydraulics takes about 2 1/2 gallons. Drain plug on the bottom of the sump pointing straight down. Same wrench. Power Director also takes about 2 1/2 gallons. Drain plug straight down from the clutch pedal. Same wrench. Transmission/differential takes approx 6 gallons. Drain plug directly under the seat. Swing the drawbar to the side. Same wrench.
Kruger
Posted: 21 May 2021 at 9:09pm |
Thanks. Answers a lot of questions
