Is 210 and 190 hood the same? |
ryanschott
Topic: Is 210 and 190 hood the same?Posted: 12 Apr 2021 at 10:45am |
Is the 210 hood the same as a 190. If not is there value in the 210 hood
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5149 |
Posted: 12 Apr 2021 at 11:37am |
no, a 210 hood is unique to the 210. They are worth anywhere from $500 to 1000 depending on condition and paint. If in rough shape, would be less.
DrAllis
Posted: 12 Apr 2021 at 11:47am |
By part numbers, all 190-190XT-200 and 210's are all different. I'm thinking you might be able to interchange a late 190-190XT and 200 onto a 210, but the muffler and air cleaner holes are probably not cut in the same spots. As a raw unfinished part, they may have been the same.
injpumpEd
Posted: 12 Apr 2021 at 2:30pm |
The 210 hood is quite a bit deeper, look at the sides where the decals are, that tells the story. Would a 190 hood fit on a 210? sure, with enough cobbling. Of course the series 1 190 hood is different from the series 2/3. The biggest difference in the series 2/3 hoods from one another is the exh hole, some were smaller for a straight pipe and others had larger hole for a round muffler.
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2206 |
Posted: 12 Apr 2021 at 6:07pm |
Wouldn't the 210 have a larger radiator? I would just assume the grill and hood was wider.
Or did they make the rad taller not wider? Leon B MO
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8737 |
Posted: 12 Apr 2021 at 10:12pm |
My 220 hood is made of plate steel instead of sheet metal....not really but it is one heavy SOB!!! You can walk down it with no ill effect.
DrAllis
Posted: 13 Apr 2021 at 6:30am |
220 hoods were stout!! 210's were same gauge as the 190 hood. The grille on a 210 is actually a late 190 grille with a mesh screen on the bottom, so that gives you a feel for the hoods width.
