D14/WD ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: D14/WD ??
    Posted: 05 Apr 2021 at 6:15pm
Other than chasis changes(and the P/D) over the years, were these 2 "close" in pulling power in a normal farming set-up back then? Are the engines at all related to each other ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 6:27pm
D14 is 149 inch............ old WD was 201..... different motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 6:30pm
different bell housing size... can not exchange motors.
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 6:42pm
The D14 to me is a lot easier to operate and get on and off, and to me the hydraulics worked much better, even though they worked similar. Around here there both 2 plow tractors, so to me they pulled about the same, maybe the WD had a little more grunt, but pretty close,
You might want to check tractor data and see what the Nebraska test were. I’m not sure but the D14 may have had a few more horsepower over the WD. And they weighed about the same.
The D14 was just way more comfortable and easier to operate.
I have 1 of each and I use the 14 a lot more than the WD, however I do like the WD.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 9:01pm
I have a WD and dad had a D14 that I wish we still had. I would definitely choose the D14 over the WD for the PD and ease of getting on and off. Both good tractors but the D14 wins hands down for those 2 reasons.
This page was generated in 0.170 seconds.
