WF final drive seal replacement
fleeter allis fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fleeter allis fan Quote  Post ReplyReply Direct Link To This Post Topic: WF final drive seal replacement
    Posted: 11 Feb 2021 at 6:50pm
Hi All, I thought I would post a few photos of a job I recently completed. The final drive fluid in my WF was looking pretty nasty and the seals were leaking, so I decided to replace the seals and change the fluid. You can see the tar leaking out in the first photo.
I removed the seal retainers and found out why. The old seals were made of cork, and could have been original for all I know. A previous owner had applied a generous coating of clear silicone caulking.
I cleaned up the final drive housings and the seal retainers.
The new seals are rubber and have some nice raised ridges to help keep the fluid in.
Greased up and ready to go back on.
The old manual calls for 250 weight gear oil. I understand that they still make it, but I was not able to source any in my area. I improvised by mixing some 85W-140 gear oil with some 0 grade grease.
I mixed them together and came up with some thick oil or some thin grease, depending on your point of view, and pumped it into the final drive housings.
Back together and ready to go.
I'm a man...and I can change...if I have to... I guess.
'44 B, '46 WF, '49 G, 810GT, 916H, 620
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 8:10pm
I'm installing the relined brake bands in one of my WF's that Rick Corder did for me a while back.  What a fun job !!!
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 9:01pm
Thanks for your nice picture presentation of the job you did. Where did you buy the new seal rings? Or a brand name  and part number for it?  Thanks for your response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2021 at 5:09am
I got new ones from Sandy Lake Equipment.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2021 at 5:54am
That is exactly the way I mixed the final drive "fluid" I suspect the WC's / WF's ? RC's leaked shortly after they were new.   Great pictures!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote fleeter allis fan Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2021 at 8:31am
I got the seals from Steiner Tractor Parts, Steiner part # ACS2105
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2021 at 12:26pm
Thanks, I appreciate all the info!
