Bearing numbers |
everett048
Topic: Bearing numbersPosted: 07 Jan 2021 at 1:27pm |
Hi can any of you guys help with crossing these 2 part numbers into bearing numbers please.
Allis part numbers 715043 & 715042
Thanks Mark
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90871 |
Posted: 07 Jan 2021 at 4:05pm |
Mark, i GOOGLE the number and it came up with an ALLIS post from 2 years ago... Nothing at that time... I still see NOTHING as a search.
I think getting ID, OD, thickness, etc might be the only way to search. |
Dirt Farmer
Silver Level Access
Posted: 07 Jan 2021 at 8:47pm |
If you can get measurements the you might try Bearing Headquarters, google it to find your nearest location
Mikez
Posted: 07 Jan 2021 at 9:13pm |
those numbers aren’t in my Allis Chalmers bearing cross reference book. But in the master numerical book they fit ED40
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4942 |
Posted: 07 Jan 2021 at 9:32pm |
they are steering box bearings for an ED-40, they don't cross in any of my old NAPA, Ford, or Deere bearing books either, shame someone hasn't documented the true bearing ID number in all these years! Just surfing and reading, it seems some have even machined their boxes to fit different bearings!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 08 Jan 2021 at 7:44am |
I wonder if other Allis Tractor Models used the same Steering Box ? EG the British D-270 or D-272, French FD3, FD4, FD5. What about other Tractor Manufacturers? G |
steve(ill)
Posted: 08 Jan 2021 at 8:17am |
Allis did NOT make bearings.. They have bought them from SKF, NGK, FAG or other... They do exist somewhere.... The problem as Joe said is no one has ever cross referenced the numbers... If you had the ID , OD, thickness , ball bearing, roller bearing, , open cage, closed cage, etc... you could get the size from the Bearing Books.
Gary
Posted: 08 Jan 2021 at 11:57am |
Steve Just curious where you got the idea that Allis manufactured bearings. G |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 09 Jan 2021 at 11:30pm |
Hey Mark!! How's the world treating you and Julie? Hope all is well with you both. Any plans to come over here and visit Hutch again this coming year? I know Jim ( wiplowboy ) had an ED40 that he was tearing into. You could PM him and see if he got into that bearing. He's a LOT of help and has a lot of knowledge and he's willing to share it. Give him a try.
steve(ill)
Posted: 10 Jan 2021 at 8:10am |
Gary, can you READ ? I said ALLIS does NOT make bearings, EIther does FORD, CHEVY, DEER or others.. You cant say since ALLIS is out of business, that bearings are NOT available... All manufactures that build equipment pick out bearings from a STANDARD CATALOG.. If you know the dimensions, the bearings are available.. In fact, i doubt ALLIS even made the gear box.. Probably was a standard, off the shelf item at that time.
Same goes with oil and grease and tires.
Gary
Posted: 10 Jan 2021 at 12:41pm |
Steve Your not on the Political Section now so it's OK to use your brain! "Allis did NOT make bearings.." I asked you a simple question, so a simple answer 'to my question' will suffice. What inspired you to post anything related to Allis manufacturing bearings ? "You cant say since ALLIS is out of business, that bearings are NOT available." Who said that ? G ..................... corrected 'note' to not Edited by Gary - 10 Jan 2021 at 4:41pm |
steve(ill)
Posted: 11 Jan 2021 at 8:42am |
YEA, keep your HATE and RAGE on the political page Gary.
ALLIS did NOT MAKE BEARINGS is a correct statement and very relative to this discussion. BEARINGS are normally available if you know the size. Very few bearing sizes have been taken off the market in the last 80 years.
everett048
Posted: 11 Jan 2021 at 12:44pm |
Ted all being well and if we can fly hope to be over in July for Hutchinson.
