7045 vs 7050 Engine Differences
AllisHunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisHunter Quote  Post ReplyReply Direct Link To This Post Topic: 7045 vs 7050 Engine Differences
    Posted: 04 Jan 2021 at 5:36pm
I have decided that I am putting another 426 in my 7045. I am exploring my options and besides rebuilding my engine, I have thought about swapping in another running one. I’ve found an engine out of a 7050 that has been out of a tractor for a few years. It has new injectors and a new pump with around 300 hours on it. I know a 7050 was aftercooled and the 7045 was not. Are there any other major difference or changes that were made to the engine between the two models? Thanks for the continued help!
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 6:09pm
I have a 426 with a intercooler on it i have more power than i have tires  i guess the thing i wonder about with a engine with a intercooler on it is if you have a big enough radiator for it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 6:10pm
mine tractor is a 7040 bought it that way i can pull any thing the 7080  pulls but  i believe its taking a toll on my rear end as  its not as quite as the 7080
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 6:42pm
The 7045 and 7050 each list a different part number for the radiator so the 7050 might have a thicker core.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 6:43pm
You can detune the 3700 engine or you can remove the intercooler if you like I suppose.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 6:53pm
Be careful as dont your 7045 have a Power Shift? That may be the next rebuild !
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisHunter Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 8:14pm
Yes it is a power shift. Is the power shift in a 7060 heavier than the one in a 7045? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 9:26pm
Same powershift.           MACK
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 1:32am
If possible, swap the 7050 radiator/engine into the 7045 & you’ll create a 7060 minus 5hp.
7060 162hp.
7050 157hp.
7045 147hp.
7045’s drive train is identical to 7050/7060 - 4 pinion diff, 2.55”ring gear,4 diff lock plates,2”finals,& 3.75”axles(7045/7060).
Exceptions: 7050 had 3.625”axles & no power shift trans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 6:12am
7045 radiator is inadequate on intercooled engines on a HOT DAY.  So, as long as you never use the engine at 100% load on days hotter than 70 degrees F, you'll probably be fine.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 6:46am
This is very interesting, thank you for the information
This page was generated in 0.246 seconds.
