wierd light issue/7060
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: wierd light issue/7060
    Posted: 19 Dec 2020 at 6:29pm
We put LED's on my 7060 today, and had a strange issue. The two head lights on the front of the cab that come on when you turn the switch to "head lights", used to always stay on when you turned the switch to "flood lights" also. But now that we changed em all out (stadium lights, too) to LED's, the two head lights go out when we turn the switch to the "flood light" position. Stadiums come on yet like they are supposed to, with the toggle switch up above. Anyone know why the two headlights would have decided to quit working in flood light position.. ? Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2020 at 6:42pm
maybe they're working correctly now ? without seeing a wiring diagram and switch 'table'..
I'd expect only flood lights to come on when flood light switch on, heads only on when heads selected..
I'm sure other 7060 owners will reply soon enough.
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2020 at 6:47pm
Those lights on the front of the cab are wired for a high and a low beam.  They have 2 wires on them (pink and blue I think) and they ground through the frame.  If your led is not setup for high/low you can connect both those wires to the positive side.  I can post a wiring diagram later if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2020 at 6:50pm
https://www.allischalmers.com/forum/allis-7060-wiring-diagram-schematic_topic139284.html
Well I just did a interweb search and a wiring diagram has already been posted.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2020 at 9:10pm
You need the high beam/low beam led lights for those two lights.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2020 at 8:56am
thanks, y'all! Darrel
