Allis Chalmers Model 500 Loader Help
gordonh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gordonh Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers Model 500 Loader Help
    Posted: 09 Oct 2020 at 7:06pm
I have a AC loader model 500 taht I need some hlep on. I have a peice that is on the hydulic pump drive that I need to know about, It connect the pump to the crank shaft. I have uploaded pictures of the peice I was wandering about. Does anyone know if the shaft rod that goes against this pecie is suppose to be welded or if it was threaded in it. Any help is apprecited. uploads/10326/IMG_1058_2.JPGuploads/10326/IMG_1059_2.JPG
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 7:10pm
What model tractor ????????? looks homemade to me.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 7:22pm
Been my experience that there is usually a keyed or splined  hub welded to that piece and the corresponding shaft slips into that hub. Supposed to make it easier to change the belt and such.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gordonh Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 7:24pm
D 17 gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 7:27pm
That ain't factory.  Factory had a splined cast iron hub and a splined shaft with a chain coupler on the pump end.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 8:37pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 6:11pm
I believe you have a Model 400 Loader if you have a front pump, Model 417 on an earlier D-17.
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 6:38pm
A and W in Wisc makes new reproduction of the assembly they have the hub and shaft along with the shaft. I have there number if interested .
Post Options Post Options   Thanks (0) Thanks(0)   Quote gordonh Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 8:39pm
Thanks can you send me the number? Do you know how to tell what model the loader is? I cannot find a serial number on it? Here is some pictures of it.uploads/10326/IMG_1063.JPGuploads/10326/IMG_1064.JPG
Post Options Post Options   Thanks (0) Thanks(0)   Quote gordonh Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 9:08pm
How will I know if it is a model 400 loader?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gordonh Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 9:26pm
D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 9:28pm
There are several differences over the span of the manufacturing. What tractor is it on? The cross bar that ties the uprights will be close to fuel tank if a 400 series. The 500 series upright is taller and bar will be several inches off of tank. Both models had a reservoir in one of the uprights on some models. Later ones did not. HTH Tracy
