D-10 SERIES III GAS TANK
BV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BV Quote  Post ReplyReply Direct Link To This Post Topic: D-10 SERIES III GAS TANK
    Posted: 01 Oct 2020 at 11:19am
i'm looking for a good gas tank for a D-10, are all series the same? mine has small pin holes in it, how can this repaired?
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2020 at 12:02pm
Use The Fuel Tank Liner Kit Steiner Has It Plus A lot Of Other Places Northern Has Blue Kote Liner Kit I Did A Lot Of Tanks That Had Pin Holes Stopped Them All Must Use The Kit Not Just The Sealer It Will Not Hold
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2020 at 11:20pm
I used Permatex gas tank repair. Comes as a little sausage, just cut off how much you may need and the knead it together, as the hardener is in the center, then apply on a clean surface. I found it to be excellent, I fixed close to half a dozen pin holes on my "B" tank and it has been perfect for several years.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 6:23am
D-10 and D-12 ranks are very hard to find. A while back PaulB was looking for one for his puller. As far as I know, hew hasn't found one yet.
I cleaned, lined and sealed a WD45 tank several year ago and had good luck. I think the secret is following the directions to the "T" and not taking any shortcuts.
If you do find a tank, Paul might be interested in your old tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 6:36am
Small pinholes ? get rid of paint,shiny it up,rinse tank with soap and water, use 250/500 watt soldering iron...
tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbird Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 5:10pm
Used the tank liner kit and it's works great save a little to put it on where out side where it's sits on the saddle strap
justinhamlett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote justinhamlett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2020 at 11:16am
What brand of gas tank cleaner and tank liner does everyone recommend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2020 at 3:16pm
It's been several years and I'm not sure if they have changed, but I used this one from Eastwood.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2020 at 6:56pm
I have repaired several automotive tanks with jb weld. Works well. Sand and paint next day. Have not had one leak yet.
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2020 at 10:45am
oriellys carrys the red kote brand, around $30. i've done several and a 60 f-100 rusty tank all turned out very good . just follow the directions and don't rush the drying time !!
