Rear work light on a WD |
Post Reply ![]() |
EPALLIS ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1151 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Sep 2020 at 5:36pm |
I realize that most model WD's came from the factory with that red rear "bullet" tail light. However, I have seen some with a rear work light instead. Not sure if this was an option or what. However, I purchased what appears to be one and would like to install it. I think I've seen a picture of one under the seat. Anyone have any thoughts on this topic? Many thanks in advance!
Roger (NE) ![]() Bronze Level ![]() Joined: 14 Oct 2010 Location: Nebraska Points: 186 |
The two WD'S we had back in the 50' & 60's when I was growing up both had rear work lights. The one on the tractor purchased new in 1949 had been added by my uncle by fabricating a bracket and mounting it to the seat mounting bolt. The other WD was purchased used and the previous owner had mounted a light in place of the red bullet light on the left hand fender. Neither was what I would term a "factory" light although they may have been available through the dealers.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5167 |
Mine has the red bullet light but I added a flood off of another WD that was being parted out. Same one I got the foot throttle off of which I really enjoy.
It wires the the same circuit as the red light but has a on/off switch. L bracket mounted on a transmission bolt under the seat.
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
The one I had, had a switch on the light. One way was a red tail light and the other way was the work light. Center was off.
Robert Musgrave ![]() Silver Level Access ![]() ![]() Joined: 11 Sep 2009 Location: SE Wisconsin Points: 241 |
WD (S/N 5109) 1949 had both the rear red bullet light on the fender and a rear work light mounted under the seat. As far as I know, both are factory original, but dad always mentioned that the chrome bezel around the red taillight was the only one he had seen. The rear work light does not have a separate switch; it comes on with the rest of the lighting. R. Musgrave
Brian F(IL) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Paxton, IL Points: 2708 |
This is my 1953 WD-45. Rear work light is mounted to a bracket that is fastened to the seat bracket. I have no idea when it was added. I'm guessing it was a dealer installed option.
Brian F: This picture is so helpful! Especially showing your tractor has the "bullet" light as well as the rear work light. The original rear work light I purchased has a bracket attached to it. So it sounds like I just need to attach it to the seat. I don't have a bullet light right now, so I can use that wire to connect to the rear work light. Thanks for all the responses.
Post Reply ![]() |
