Why the overlap in 170/175 production |
Jason n
Topic: Why the overlap in 170/175 productionPosted: 13 Sep 2020 at 7:45pm |
Always wondered why ac continued to make the 170 for 3 additional years after the 175 came out?
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5469 |
Posted: 13 Sep 2020 at 7:53pm |
My guess is the 175 was powered by the Perkins diesel and there were still folks that wanted the same size tractor but in the gas version. JMO
DougG
Posted: 13 Sep 2020 at 7:55pm |
They did the same with One Eightys and 185,s ,, all the same componets,s just a little horsepower tweaking,
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Posted: 13 Sep 2020 at 8:02pm |
Pretty sure they made a 175 gasser.
Jason n
Posted: 13 Sep 2020 at 8:06pm |
They made both models with 236 perkins or a 226 gas. I believe 175 gas put out couple more horses than 170 gas. Diesels were the same till 175 went to 248 perkins diesel in 1972
DrAllis
Thanks(1)
Posted: 13 Sep 2020 at 8:44pm |
Two different HP/sizes of tractors !! 170 was 54 HP gas and diesel. 175 was 60 HP gas and 62 HP diesel.
175's all had 180/185 final drives which were stronger than 170 final drives.
Edited by DrAllis - 13 Sep 2020 at 8:56pm |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Posted: 13 Sep 2020 at 11:25pm |
Besides their improvements, the 175 & 185 models were marketed as “Crop Hustlers” themes. Basically they could pull same tillage equipment used by the previous older 170 & 180 models, but did so a little faster.
DrAllis
Posted: 14 Sep 2020 at 7:20am |
At that time Deere had replaced the 2510 (53 HP) with the 2520 (60 HP). So, it made sense for AC to come up with a model to directly compete with it. Kind of the same thing with the 185 (74 HP) versus the One-Ninety (77 HP). The 185 was cheaper to build and sell and on many jobs was handier. Few straight One-Ninety's were sold in favor of the more powerful "XT" for a few hundred dollars more.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 14 Sep 2020 at 7:42am |
from '70 to '73 Allis offered: All at pto hp at rated engine speed 160 = 40 dsl hp 170 = 54 gas & dsl hp 175 = 61 gas/62 dsl hp (in late '70 the 236 perkins was replaced by a 248 perkins... not sure which was tested at Neb.) 180 = 65 gas/64 dsl hp 185 = 75 dsl hp 190 = 75 gas/77 dsl hp (may have been dropped before 1973 190 XT = 90 gas/94 dsl hp (later ones with engine upgrades were not tested) replaced by 200 in '72 200 = 94 dsl hp (started in '72 & sold under the old 1965 190XT hp but was more likely around 105 to 110 hp.) 210 = 122 dsl hp 220 = 136 dsl hp The the 440 came in 1972 and the 7030/7050 in 1973
Wink I am a Russian Bot |
Tracy Martin TN
Posted: 14 Sep 2020 at 10:43am |
I would like to find a low hours 175 gasser.Handy tractor! Tracy
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4276 |
Posted: 15 Sep 2020 at 7:23am |
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11858 |
Posted: 15 Sep 2020 at 8:52am |
According to the Nebraska test data, the difference between the 175 and 170 gas horsepower appears to be due to compression ratio of 8.2 versus 8.0 and carburetor size of 1-1/4” vs. 1-1/8”. A penalty in fuel efficiency resulted also.
DrAllis
Posted: 15 Sep 2020 at 9:09am |
Camshaft grind is different on the 175.
gleaner1
Posted: 15 Sep 2020 at 4:33pm |
Up till about two years ago I had no idea a gas 175 even existed.
There must have only been a handful built. |
ALLIS CHALMERS "The color is orange"
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 15 Sep 2020 at 6:32pm |
1009 total gassers built as per Tractor Data ![]() ![]() I see that the diesel versions came with 2 different CI Perkins engines ??
Edited by FREEDGUY - 15 Sep 2020 at 7:55pm |
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2337 |
Posted: 15 Sep 2020 at 8:08pm |
Neighbor had a 175 Gas, when he moved off the farm he wanted to sell it to me, I wanted it but just couldn't swing it, he sold it to someone in Minn.
Lonn
Posted: 15 Sep 2020 at 8:33pm |
