char-lynn seal kit
mhankins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Topic: char-lynn seal kit
    Posted: 07 Sep 2020 at 8:25am
I am looking for a seal kit source for the torque multiplier on my wd45.
So far all I have found are the seal kits for the pump,but mine is leaking out of the lower
 seal where the steering shaft connects.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 8:52am
Measure the seal and you should be able to find one on line pretty easy.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 9:06am
A local hydraulic shop should have what you need.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 4:54pm
Try this
Eaton power products
No.21122
I ordered this from Force America several years ago, its a complete seal kit, with instructions on how to "time" the gears..
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 8:56am
Thanks Michael. I couldn't find that part number listed,but I will contact the company.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 11:14am
here ya go
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 3:16pm
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 9:38am
Midwest steering has the seal kits if anyone else is looking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 8:44am
HELP!!
 Ok,finally got around to taking the multiplier off and replaced the seals,butt...
when I tighten everything down it will not turn. I timed it according to the pics above and tried the spacers in each position.The coupler shaft that goes between the rotor and the out put shaft at the lower part has different thickness splines on either end and I have tried those in each position.
 This is a series 101 which shows a little difference than the one pictured as to how many seals are used as mine doesn't have the larger orings sealing the case and spacers.
 Any Ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 5:47pm
Never mind,got it going
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 8:13pm
Want to fess up ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 7:39am
Put it together from the bottom up instead of the top down.
??? worked
This page was generated in 0.934 seconds.
