Allis Chalmers Model C crankshaft front oil seal
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers Model C crankshaft front oil seal
    Posted: 05 Sep 2020 at 8:23am
Hi
I'm looking for the size of the crankshaft front oil seal for my C ;  Engine Number is CE 71315
It is a  year 1947.
The seal reference according to AGGCO, should be 70206953. But i can't find it on the market.
Does anyone have the size of the seal? or Where i could find the size of the seal?
Do you know if it a lip seal as these days and do i need to put a speedy sleeve to avoid leak?
The tractor number on the gear box is C 50953.
It seems that, may be,  there are 2 seals together. One for oil,  the other one for dust ( felt seal)?
Edited by John426 - 05 Sep 2020 at 12:08pm
C in Concord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2020 at 9:01pm
I have a cork seal leftover from a C gasket set.  It's not cut real square, but the measurements are 1.81" OD, 1.41" ID, 0.125" thick.  The factory setup sandwiches the seal into a housing.
Converting to a lip seal with a speedi-sleeve seems to be the most popular route.  The spiral grooves in the crank will destroy a lip seal without the sleeve.
Based on the dimensions of the seal, using just the felt from seal assembly 70226620 (better availability) may work also.
Ben
Leave things better than you found them.
1941 Model C (restored 2020)
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 12:02pm
Are you sure that the 70226620 , have same size than  70206953?
Edited by John426 - 06 Sep 2020 at 12:40pm
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 1:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 7:34am
Does a wide of  0.530" could be put on the place ?  Not to wide?
instead of the original 0.25" wide
Edited by John426 - 08 Sep 2020 at 7:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 12:56pm
Just the felt portion of 70226620 may be close enough to 70206953.  Take it as an idea, not a tried and true solution.
0.53" is the thickness of the entire 70226620 seal assembly.  You would only be using the felt portion (removable), which will be closer to 0.25".  Again, this is only an idea.  Please do let us know if it works out, should you try it.
Ben
Edited by C in Concord - 08 Sep 2020 at 1:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2020 at 8:38pm
You've probably sorted this out already, but I did get an opportunity to try out my idea above.  Used only the felt ring from seal assembly 70226620 in the front crank seal housing on my C...  It works!
Lip seal w/speedi-sleeve is a better long-term solution.  Good to have options though!
Ben
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2020 at 10:50am
Google "226620 seal"  it is out there.  That is the original number the "70" was added by AGCO much later.
This page was generated in 0.127 seconds.
