Sunflowers And Conventionals ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Sunflowers And Conventionals ?
    Posted: 25 Aug 2020 at 5:05pm
Have any of you members ran sunflowers with a K,F,M,L series machine ?? Is there a special sieve? Are they run with a grain table or corn head? Just curious as I've been driving past a "large" garden with an abundance of 4' tall "flowers" that will probably be harvested as an "entire" head, and was curious how they would get harvested on a large scale for the actual seed Smile. Thanks
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 5:41pm
ez to thresh , issue is heads hanging over the  header sides and clogging.  There were special long dividers and finger extensions to prevent head loss.  Book setting were spot on.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 8:46pm
Did 100s of acres with a C2 and then M2.  Sunflower pans were the cheap attachment, bolted on regular straight head, later used a JD all crop head.  There are companies making heads that look like corn heads but use a gathering belt.  About the only thing needed for the combine is a cylinder slowdown kit to get to about 400 rpm.
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 8:59pm
One thing about them after a day cutting your combine will be smooth and quiet as can be.  Harvested them in a L2 and boy was she a smoothly oiled machine Wink
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 6:09am
We ran them with a R52 neighbor ran them with a M2 then a 9400.  We had pans made for the 520 neighbor used a Deere Allcrop head.  A kit existed to make it so a cornhead would work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 8:51am
I have no experience but have heard that there is a danger of fire from build up of dust? or something so need to know what to look out for. It was said that certain combines are more suceptable to fires but another said sunflowers will burn down all brands....so be carefull/aware.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 8:40pm
There was a 90 pull type listed on Syracuse Craig about a month ago that had a factory kit for sunflowers. Wish I had bought it now
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 10:05pm
We did oil seed flowers one year, harvested with a 81 L2 pushing a 6r30 Jd all crop header on a Bish plate to fit the Gleaner.
IIRC cylinder settings similar to corn, I think we used the corn chaffer and only enough air to keep it clean.
As far as fires, no combines are immune to fires, but it seems Gleaner designed the conventionals to be as fire proof as a combine can be. There is a reason the ribs on the side of the body are angled down. very few places for chaff to collect.
Engine sits up high, tight compartment with hood closed to keep air velocity high enough to self clean, etc.
Overall loved to harvest them, also helped a bigger farmer who ran 30' Lucke pans on a rigid platform, but our local confection market dried up thanks to mis-management, and oil prices are not good enough to appeal to us, and there seems to be quite the weed pressure during and after, so we didnt raise them again, and the big farmer I help sold his stuff off so hes definitely out of the sunflower business as well.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2020 at 7:52pm
Raised oil sunflower for about 20 years, finally got some bugs and a little disease but our biggest problem was black birds.  They came in the fall and could eat a lot in a hurry, they dropped more than actually ate but the damage was done.
