A fun day with 172 A/C mower in the field
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Topic: A fun day with 172 A/C mower in the field
    Posted: 19 Aug 2020 at 11:17pm
Opened up the fields with series 3 and the model 307.Then went to the A/C 172 on the 45d after some preventative maintenance on the mower,sharpening, greasing,checking gear box ,etc.Wow was I surprised how well these A/C mowers cut.A fun day listening to that old buda hum all afternoon.This is the mower from the Bill Mishler sale.A fun day with the new to me mower!!
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 7:32am
Any reason the height adjuster is set to the rear bracket?  Mine was connected to the front, I never thought anything about that, and have just left it.
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 7:52am
Which way are your wheels,to the front or the rear?The jack gets attached to the rear bracket with wheels in the rear position and to the front if wheels are to the front according to the operators manual,that's all I know.
Edited by ac45dave - 20 Aug 2020 at 8:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 9:01am
My uncle has one of those AC choppers. Always did a more complete job of cutting than dads woods. I often wondered if the blade spins faster. It's been years since I used it but it sounded faster. It had the dual blade setup...one near the deck and a drop down one that cur close to ground. You got a steal of a deal on that one. Take care of it and it will out last you. They are tuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 9:37am
Steve they definitely run faster.I can tell the difference from running the two mowers, between the bush hog 307 and this A/C cutter.I'm liking it.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 10:00am
Oh yeah, these old AC mowers are fantastic! The 172 looks great. Even mine, with a horribly dull blade, does an amazing job of cutting, almost like a finish mower.
I've got on my to-do list to get new blades for my 160.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 10:35am
My wheels are set behind the mower.  So, I guess, the jack should connect to the rear bracket.  Maybe that is better for keeping it level, as I noticed the front is lower than the rear of the mower deck.  Dave
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 11:15am
Couple advantages to having the wheels to the rear,can cut closer and the weight of the cutter is on the rear of the tractor giving better traction.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 1:11pm
Nice mower. Why isn't the hydraulic cylinder attached to the axle arm extension? I'm having one of those as well as an anchor being made right now so I can put a hydraulic cylinder on one. What's the serial number on yours?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 1:22pm
I don't think the cylinder would raise it much if hooked to the long lever. They only travel 8in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 6:12pm
  Jim I pulled the pin on the cylinder to use the manual jack for the day.The hydraulics on the 45 diesel aren't working at this time so I was going old school for the day.The cylinder works great,just didn't have hydraulics for this run.I haven't been able to find the serial number.Where is it located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 7:22pm
I use a single action cylinder with my 172 shredder and while it doesn't lift the mower a tremendous amount, it is nice to use for road transport and uneven field surfaces where the mower bottoms out.  Plus, its cool to have and use!
Is your cylinder for low pressure or high pressure hydraulics?  Your D17 III would be low pressure while the '45 would be high, so you need the correct cylinder or you'll blow it out with the '45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 7:37pm
Series 4 is low pressure not 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 8:33pm
Dave, I believe the cylinder to be a high pressure cyl(screwed together).I put a new hyd hose on it while on the series 4 d17.Once I had it bled out it was a very quick response.I haven't had it on the series 3 d17 yet.My Series 3 is still high press low volume system.
Edited by ac45dave - 20 Aug 2020 at 9:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 9:46pm
Jim, after looking at the manual again I found the location of the serial number.The info was in the "how to order parts" section at the beginning of the parts section of the book.Serial # is 6-7508.Here's pic  of inside the front cover of the manual and the number on the mower.Looks like original owner was Dick Koons.I guess Bill Mishler got the original manual when he bought it back in the day.This is the second piece of allis equipment that I have acquired with the original manual in the last eleven months.Don't see that too often.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 10:25pm
Dave,
That's  neat that you got the original manual with it. Is there any date in the manual? I have two mowers, serial numbers 6-1740 and 6-10078 but no idea on the years. I just finished mowing around 30 acres with one, when I stop for the day, there's always a wheel barrow or two of clippings to clean off. I am "restoring" one mower and had the A-C chain guards made for the front and rear, maybe that will help keep debris off the deck as well as protect me from flying objects.
D14JIM14 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 6:27am
I'm glad you are enjoying the mower !
The cylinder was always used with a wd45 . I'm sure it's a high pressure . It was never a problem .
Jim Mishler Bill's brother.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 7:36am
So, D17 III was still high pressure hydraulics?  I had thought that changed with the series III.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 8:38am
 No, only the series IV D17 had low pressure, high volume hydraulics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 9:52am
Dave,
That's  neat that you got the original manual with it. Is there any date in the manual? I am "restoring" one mower and had the A-C chain guards made for the front and rear, maybe that will help keep debris off the deck as well as protect me from flying objects.
JIM, so far I haven't found any dates in the manual.I am also on the hunt for chain guards for mine.Who made your guards,any pics?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 10:01am
Hey Jim, I really am happy with mower.It does a great job. I wish I could have got to talk to you longer the day we picked up our stuff.Do you have any idea when and how Bill came to acquire the mower, private owner,estate sale,etc.?I was just curious.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 10:57am
I know that he bought it in a private purchase when he bought the wd45 lot 20 , 4 bolt wide front end anti shock steering wheel .
I think around Martinsville , Indiana . About 6-7 years ago . I really liked using them together.
I have no idea what the guys name is .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 11:11am
  The name inside the front cover of the book is Dick Koons.I'm always interested in history and the stories behind the stuff I run across.I feel it's part of the fun of collecting these things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 8:53pm
Edited by JimWenigOH - 21 Aug 2020 at 8:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 9:01pm
The shields were made by Schmidt Machine Co. near Upper Sandusky, OH. If you're interested, give Konner Holloway a call at 866-368-3814. He has these saved in his system. The only thing I'd change is to have the chain holes enlarged a bit. The chain fits in ok when unpainted, but needs some nudging when painted. Other than that they are perfect. You drill the holes.
Edited by JimWenigOH - 22 Aug 2020 at 6:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 7:22am
Jim, WOW those look spot on the originals.Just might have to give those folks a call.Did you have the dimensions off the originals for them to work from?
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 2:06pm
Any idea of a rough cost for those brackets? Kind of tempting to get a set for my 172.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 2:11pm
G_G, I"m in the process of checking my options for these.I'll let you know what I come up with.
Stateliner1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stateliner1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 9:11pm
Dick Koons was an equipment dealer that sold AC and MF in Connersville, IN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 1:55pm
Awesome, thanks!
